question with 3602i APs and WLC 5508
                   Hi all,
    Please help with the following question : we have an existing wireless network (I'm new to this Cisco wireless) and broadcast several SSIDs. Each SSID is in separated VLAN so how do I find and config certain SSID into a different VLAN ? for example, I'm interesting in SSID named "BLDG-A" then check on the registered clients and find out those clients are in subnet : 172.16.1.0/24, but I need to config "BLDG-A" into subnet 182.168.1.0/24. Please educate me. Thank you very much.
1 REPLY
VIP Purple
Re: question with 3602i APs and WLC 5508
HI Duc,
Each ssid is connected to dynamic interface.so first check that this ssid is connected to whcih interface.
How to check: see the pic wlan1
You can check this interface and change there: ip address, mask and gateway. see the pic wlan2
Here is the config guide for Dynamic interface:
http://rscciew.wordpress.com/2014/01/22/configure-dynamic-interface-on-wlc/
123
