Community Member
Radius Key Recovery on 4400 WLC
Greetings, can i ask if it is possible to recover a Radius key from a 4400 Controller. I do already have the encrypted key from the config but was wandering if its possible to generate it in clear text in a similar fashion to how you can recover PSK's from the ASA platforms using "more system:running-config".
I do realise that it's not too much effort to change the key on both the radius server and on the controller but we have recently had a key miss match following a rebuild of a Windows DC running IAS and i need to know what key was used prior to the rebuild.
366
