Radius not Authenticating issue, AP
Hey Guys,
I am not able to authenticate USer and while running debugging I am getting the following logs. Can anyone help me to resolve this issue, anyways I have already checked the radius server and its fine so the issue could be else.
*Jul 24 16:01:23.171: RADIUS:  AAA Unsupported Attr: ssid              [346] 8   131862908
*Jul 24 16:01:23.171: RADIUS:  AAA Unsupported Attr: service-type      [344] 4   1
*Jul 24 16:01:23.171: RADIUS:  AAA Unsupported Attr: interface         [221] 3   131863776
*Jul 24 16:01:23.175: RADIUS(0000001A): Config NAS IP:  10.9.9.9
*Jul 24 16:01:23.175: RADIUS(0000001A): Config NAS IPv6: ::
*Jul 24 16:01:23.175: RADIUS/ENCODE(0000001A): acct_session_id: 16
*Jul 24 16:01:23.175: RADIUS(0000001A): sending
*Jul 24 16:01:23.175: RADIUS(0000001A): Sending a IPv4 Radius Packet
*Jul 24 16:01:23.175: RADIUS(0000001A): Send Access-Request to 10.1.1.1:1812 id 1645/14,len 156
*Jul 24 16:01:23.175: RADIUS:  authenticator 7B 67 44 37 AA 69 7A E7 - E8 9E A9 63 68 7E 1F 6C
*Jul 24 16:01:23.175: RADIUS:  User-Name           [1]   11  "AUS/Khan"
*Jul 24 16:01:23.175: RADIUS:  Framed-MTU          [12]  6   1400
*Jul 24 16:01:23.175: RADIUS:  Called-Station-Id   [30]  28  "DB-A5-F6-65-F7-E0:ATssid"
*Jul 24 16:01:23.175: RADIUS:  Calling-Station-Id  [31]  19  "15-0B-B9-99-CC-4C"
*Jul 24 16:01:23.175: RADIUS:  Service-Type        [6]   6   Login                     [1]
*Jul 24 16:01:23.175: RADIUS:  Message-Authenticato[80]  18
*Jul 24 16:01:23.175: RADIUS:   6D CF 22 F0 2A D0 49 24 DF FA DF AD A3 95 0B 3F            [ m"*I$?]
*Jul 24 16:01:23.175: RADIUS:  EAP-Message         [79]  16
*Jul 24 16:01:23.175: RADIUS:   02 02 00 0E 01 55 4B 5C 6D 6F 69 73 65 63         [ AUS/Khan]
*Jul 24 16:01:23.175: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
*Jul 24 16:01:23.175: RADIUS:  NAS-Port            [5]   6   270
*Jul 24 16:01:23.175: RADIUS:  NAS-Port-Id         [87]  5   "270"
*Jul 24 16:01:23.175: RADIUS:  NAS-IP-Address      [4]   6    10.9.9.9
*Jul 24 16:01:23.175: RADIUS:  Nas-Identifier      [32]  9   "AP-Test"
*Jul 24 16:01:23.175: RADIUS(0000001A): Started 5 sec timeout
*Jul 24 16:01:28.199: RADIUS(0000001A): Request timed out!
*Jul 24 16:01:28.199: RADIUS: Retransmit to (10.1.1.1:1812,1813) for id 1645/14
*Jul 24 16:01:28.199: RADIUS(0000001A): Started 5 sec timeout
*Jul 24 16:01:33.223: RADIUS(0000001A): Request timed out!
*Jul 24 16:01:33.223: RADIUS: Retransmit to (10.1.1.1:1812,1813) for id 1645/14
*Jul 24 16:01:33.223: RADIUS(0000001A): Started 5 sec timeout
*Jul 24 16:01:38.247: RADIUS(0000001A): Request timed out!
*Jul 24 16:01:38.247: RADIUS: Retransmit to (10.1.1.1:1812,1813) for id 1645/14
*Jul 24 16:01:38.247: RADIUS(0000001A): Started 5 sec timeout
*Jul 24 16:01:43.271: RADIUS(0000001A): Request timed out!
*Jul 24 16:01:43.271: RADIUS: Fail-over to (10.2.2.2:1812,1813) for id 1645/14
*Jul 24 16:01:43.271: RADIUS(0000001A): Started 5 sec timeout
*Jul 24 16:01:48.295: RADIUS(0000001A): Request timed out!
*Jul 24 16:01:48.295: RADIUS: Retransmit to (10.2.2.2:1812,1813) for id 1645/14
*Jul 24 16:01:48.295: RADIUS(0000001A): Started 5 sec timeout
*Jul 24 16:01:53.319: RADIUS(0000001A): Request timed out!
*Jul 24 16:01:53.319: RADIUS: Retransmit to (10.2.2.2:1812,1813) for id 1645/14
*Jul 24 16:01:53.319: RADIUS(0000001A): Started 5 sec timeout
*Jul 24 16:01:58.343: RADIUS(0000001A): Request timed out!
*Jul 24 16:01:58.343: RADIUS: Retransmit to (10.2.2.2:1812,1813) for id 1645/14
*Jul 24 16:01:58.343: RADIUS(0000001A): Started 5 sec timeout
*Jul 24 16:02:03.367: RADIUS(0000001A): Request timed out!
*Jul 24 16:02:03.367: RADIUS: No response from (10.2.2.2:1812,1813) for id 1645/14
*Jul 24 16:02:03.367: RADIUS/DECODE: No response from radius-server; parse response; FAIL
*Jul 24 16:02:03.367: RADIUS/DECODE: Case error(no response/ bad packet/ op decode);parse response; FAIL
*Jul 24 16:02:03.367: %DOT11-7-AUTH_FAILED: Station XXXX.a999.XXXX Authentication failed
VIP Purple
Check the port numbers on both sides.
Cisco uses the 1645 and 1646 by default, but you must use the 1812 and 1813, so If there is a port mismatch your RADIUS environment will not work.
I tried with Default port and
I tried with Default port and seeing same error;
 RADIUS: No response from (10.104.214.5:1645,1646) for id 1645/32
any one have the same issue ?
Bronze
Hi,have you tried after
have you tried after increasing the handshaking timeout, if you are using WPA
Go into the interface Dot11Radio0
dot11 wpa handshake timeout 500
Gold
Refer the link :http://www
Refer the link :
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/50843-debug-authen.html#EAP
https://learningnetwork.cisco.com/thread/35468
210
