Community Member
Reboot Cisco Aironet 1200
I want to know if its posible to reboot my Cisco Aironet 1200 via snmp, if so, could anybody send me the oid to do such work? I've been looking for a useful MIB last couple of weeks but I've couldn't find anything.
Thanks in advance
kka
Community Member
Re: Reboot Cisco Aironet 1200
Try OLD-CISCO-TS-MIB::tsMsgSend.0 (1.3.6.1.4.1.9.2.9.9.0).
Don't forget to enable shutdown per SNMP by adding the
following line to the config:
snmp-server system-shutdown
Works at least on AP1231G with IOS 12.3(7)JA2.
Community Member
thanks kka, it works perfect. You where right, before anything I had to enable snmp-server system-shutdown, after that I could reboot my AP without any problem.
My AP is a Cisco Aironet 1200 with IOS 12.3(4)JA
Community Member
hi there,
I have just one more question: how can I make permanent the snmp-server system-shutdown? My problem is that when I reboot the system this option is desactived. I mean, i can't reboot twice my AP.
Thaks in advance
kka
Community Member
Did you save the config to nvram?
"copy run start" or "write mem"
Just checked, works at least with IOS 12.3(7)JA2.
2461
