Recommended Router Settings for ISP provider?
My company is providing internet service to an apartment complex. The connection to the internet provider (UUNet) is through a 2620 cisco. The router feeds 1900 switches in each building. What is the recommended settings we should consider in the router for security?
Re: Recommended Router Settings for ISP provider?
You could run the firewall feature set http://www.cisco.com/warp/public/cc/pd/iosw/prodlit/fwfs_ds.htm on the 2600 or better yet, drop a PIX firewall in between your nework and the 2620 if UUnet manages it.
I have used the following references in a similar situation...
- Cisco's Security Configuration Guide at http://www.cisco.com/univercd/cc/td/doc/product/software/ios112/112cg_cr/2cbook/
- Hardening Cisco Routers by O'Reilly at http://www.oreilly.com/catalog/hardcisco/
- Router Security Configuration Guide at http://nsa2.www.conxion.com/cisco/guides/cis-2.pdf
These references have very useful information to help you harden your router and to make your network more secure. Hope ti helps.
John Rumball, CCNA
You could look at the InfoSec guides at www.nsa.gov
410
