Recover WEP Key
Is there a way to export or recover your current WEP key from the AP's config, or from a .pro that was created with the Aironet Client Utility?
1 REPLY
Silver
Re: Recover WEP Key
If you need the WEP key then there is no way to recover it, you just need to re-enter a new WEP key. If you requirethe password to get into set WEP then there is a problem.. There is no password recovery on a bridge. The only solution is to get a eplacement unit.
239
