Redundent IAS Server Questions with certificates and PEAP
Currently we have about 16 5508 ( at diffrent locations) controllers authentication to one DC running IAS. We've noticed some issues with users not being able to connect sometimes and have decided to install IAS on our secondary DC and have half of the controllers point to the new IAS server.
I'm following this guide:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080921f67.shtml#conwirecli
However, it 3/4 of the way it starts to talk about certificates? I was under the assumption PEAP using IAS does not need client side certificates since it will be authentication to a Active Directly group?
Does anyone have any thoughts on this?
Dan
  • Security and Network Management
Re: Redundent IAS Server Questions with certificates and PEAP
Hi Playne,
If you deploy PEAP its a requirement on the server only, not the client. The prupose of the side certificate is to establish a TLS tunnel for the client to send its logon. This is a server side cert only.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
I just took a peek at your reference and I understand your possible confusion. That is showing that the client vaildate the certificate the server is sending. This is not a requirement rather its optional.
This prevents a man in the middle attack.
Thanks George for the help. The server that I'm setting this up for is actually a windows server 2008. The Cisco guide for for setting PEAP with windows server 2003. So when it gets to the cert parts its a little off.
Do you know of any documents for setting up PEAP with Windows server 2008 (NPS)
thanks for the help,
Dan
Hall of Fame Super Silver
You can find may guides on how to configure 2008 NPS using PEAP.  The WLC config is the same and IAS and NPS are very similar.
Here is one:
http://www.itechtalk.com/thread1887.html
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
403
