Community Member
Regarding WiSM configuration
WiSM is installed on 6509. There are 85 AP's installed and being conrolled by chassis switch 6509. All AP's are running on VLAN 76 and have one dhcp pool assigned I want to segregate this pool and create 10 different vlans and assigned one pool to one vlan. So whenever a user is in one particular VLAN, he should be assigned IP from that IP pool which belongs to the vlan in which user resides. kindly suggest the configuration required to achieve the desired result?
Hall of Fame Super Blue
Re: Regarding WiSM configuration
Sounds like 802.1X to me.
As Leo pointed out you would want to use 802.1X with Dynamic VLAN assignment. This will allow you to broadcast 1 SSID butplace users on different VLANS. Thats what you want right?
Search dynamic vlan assignment in the search bar
Please remember to rate helpful post ...
