remote AP dropping - resolved
We have a Cisco 5508 wireless controller with approx 12 local wireless APs (1131 + 1042N) and 7 remote APs (H-Reap).
I have recently added another remote AP but am having issues.
When it is connected to the local network, the wireless controller has no problems finding it and everything is ok, but when plugged into the remote network the wireless controller can see it for less than 5 seconds then it drops off, then about 30 seconds later it appears and then drops again after 5 seconds. This just keeps continuing.
Pinging the wireless AP is constant with no drops.
When plugged into the local network, the AP shows as H-Reap, but on the remote network, shows as local on the controller, however Im thinking this is only because the controller doesnt get to see the AP long enough to get its settings.
I have compared all settings between other remote APs, and compared the settings on the WLan and contoller interface created with other working ones.
Everyone's tags (3)
Hall of Fame Super Silver
Re: remote AP dropping
Have you tried to put it on a different switchport? I have seen this behavior with bad patch cables or bad cable runs. Also look at the switchport and see what the port is negotiating to.
Sent from my iPhone
-Scott
remote AP dropping
I have now tried different cables, running though a cisco switch and also trying different speeds. still not working properly. The unit has worked for 2 years in a different site, i then wiped it and configured for a new one. I have tried to match everything with a current working site.
Hall of Fame Super Gold
See if the WAP has a crashinfo file/directory present.
Another thing, what switch is the WAP plugged into?  I mean can you provide the model number?
switch is a 3750G
how do I check the crashinfo on the WAP?
remote AP dropping
switch is a 3750G
PERFECT!
Run the following commands:
1.  Command:  test cable tdr interface ;
2.  Wait for about 5 to 7 seconds;
3.  Command:  sh cable tdr interface ; and
4.  Post the output.
Leave the speed and duplex to auto.
Sent from my iPhone
-Scott
I ran twice. After the first results I changed network cable and port, cables have been tested and working.
TDR test last run on: March 01 00:54:59
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/19  100M  Pair A     0    +/- 4  meters Pair A      Normal
                Pair B     60   +/- 4  meters Pair B      Fail
                Pair C     48   +/- 4  meters Pair C      Fail
                Pair D     56   +/- 4  meters Pair D      Fail
Switch#
TDR test last run on: March 01 01:02:17
Gi1/0/9    100M  Pair A     2    +/- 4  meters Pair A      Normal
                Pair B     8    +/- 4  meters Pair B      Normal
                Pair C     50   +/- 4  meters Pair C      Fail
                Pair D     150  +/- 4  meters Pair D      Normal
Switch#
Switch#
remote AP dropping
Nice.  Very, very nice.
Look at your 2nd test.  See Pair C?  This pair controls PoE.  See the result under Pair Status?  This is why your WAP bounces.
Wow.  That's one lousy cable you got.
How to use Time-Domain Reflectometer (TDR)
This isnt a PoE switch, Im using a seperate power supply. Previously it was on a PoE switch on a different site.
There are no drop outs on pings.
I have cable tested all cables and used both Cat5e and Cat6 cables.
remote AP dropping
The only cable tester result our organization will accept (as a standard) is from a Fluke DTX1800.
remote AP dropping
when i plug the unit into our main network (local) using the same cat6 cable the unit works perfectly.
remote AP dropping
Console into the AP and post the following output:
1.  dir
2.  sh version
remote AP dropping
below I have inclided the dir and sh version. Also when I consoled onto the unit logs were being displayed which I have included part below also.
1. dir
Directory of flash:/
    2  -rwx         280  Nov 16 2011 12:03:56 +00:00  lwapp_officeextend.cfg
    3  -rwx         293  Nov 16 2011 12:03:56 +00:00  env_vars
    4  drwx         128   Jan 1 1970 00:01:55 +00:00  c1130-rcvk9w8-mx
    7  drwx         320  Mar 30 2011 20:26:55 +00:00  c1130-k9w8-mx.124-23c.JA
    9  -rwx        5144  Nov 16 2011 12:07:12 +00:00  private-multiple-fs
    8  -rwx       69890   Mar 1 2002 00:07:08 +00:00  event.log
   13  -rwx       25844  Nov 16 2011 12:07:12 +00:00  lwapp_reap.cfg
15740928 bytes total (8786432 bytes free)
2. sh version
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 01-Jun-10 13:18 by prod_rel_team
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (fc2)
Cisco-1131-TRAMSFLAT-AP1 uptime is 7 minutes
System image file is "flash:/c1130-k9w8-mx.124-23c.JA/c1130-k9w8-mx.124-23c.JA"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1131AG-E-K9   (PowerPCElvis) processor (revision B0) with 25590K/7168K bytes of memory.
Processor board ID FCZ1332Q21U
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 7.0.98.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:25:45:B0:43:A0
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC13292GAR
Top Assembly Part Number             : 800-29144-03
Top Assembly Serial Number           : FCZ1332Q21U
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131AG-E-K9
Configuration register is 0xF
Cisco-1131-TRAMSFLAT-AP1>
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
*Nov 16 11:51:58.947: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceed., 1)x(UNKNOWN_MESSAGE_TYPE (5)
*Nov 16 11:51:58.947: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Nov 16 11:51:58.947: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.16.250.20:5246
*Nov 16 11:51:58.997: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov 16 11:51:59.064: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov 16 11:51:59.093: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 16 11:51:59.093: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 16 11:51:59.122: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Nov 16 11:52:08.081: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Nov 16 11:52:17.082: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Nov 16 11:52:17.083:  status of voice_diag_test from WLC is false
*Nov 16 11:52:27.083: %CAPWAP-3-ERRORLOG: Selected MWAR 'Cisco-HQ-5508-Grnd-C'(index 0).
*Nov 16 11:52:27.083: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov 16 11:52:27.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.250.20 peer_port: 5246
*Nov 16 11:52:27.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Nov 16 11:52:28.709: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.250.20 peer_port: 5246
*Nov 16 11:52:28.710: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.250.20
*Nov 16 11:52:28.710: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Nov 16 11:52:33.708: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.250.20
*Nov 16 11:52:33.939: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Nov 16 11:52:51.937: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceed., 1)x(UNKNOWN_MESSAGE_TYPE (5)
*Nov 16 11:52:51.937: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Nov 16 11:52:51.937: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.16.250.20:5246
*Nov 16 11:52:51.984: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov 16 11:52:52.047: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov 16 11:52:52.077: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 16 11:52:52.078: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 16 11:52:52.106: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 16 11:53:01.065: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Nov 16 11:53:10.066: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Nov 16 11:53:10.067:  status of voice_diag_test from WLC is false
*Nov 16 11:53:20.067: %CAPWAP-3-ERRORLOG: Selected MWAR 'Cisco-HQ-5508-Grnd-C'(index 0).
*Nov 16 11:53:20.067: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov 16 11:53:20.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.250.20 peer_port: 5246
*Nov 16 11:53:20.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Nov 16 11:53:21.763: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.250.20 peer_port: 5246
*Nov 16 11:53:21.764: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.250.20
*Nov 16 11:53:21.764: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
I agree on the tester:) Have you just connect the AP right into the switch to at least eliminate the cable run and the patch on the other end?
Sent from my iPhone
-Scott
remote AP dropping
AP and switch are plugged directly.
I have tried to eliminate as many variants as possible when moving the AP between the new setup (with issues) and the local network (which works)
What are your ping times between ap and wlc?
Sent from my iPhone
-Scott
remote AP dropping
between 80ms - 120ms
remote AP dropping
Have you tried to reset the AP and is it one AP or a bunch?
-Scott
remote AP dropping
just one AP on this site and has been reset.
I have fixed the error about dns resolutions but still have the loop below
*Nov 16 14:21:39.046: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov 16 14:21:39.047: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov 16 14:21:39.110: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov 16 14:21:39.128:  status of voice_diag_test from WLC is false
*Nov 16 14:21:39.139: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov 16 14:21:39.140: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to down
*Nov 16 14:21:39.141: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 16 14:21:49.128: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Nov 16 14:21:49.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.250.20 peer_port: 5246
*Nov 16 14:21:49.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Nov 16 14:21:50.736: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.250.20 peer_port: 5246
*Nov 16 14:21:50.737: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.250.20
*Nov 16 14:21:50.737: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Nov 16 14:21:55.737: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.250.20
*Nov 16 14:21:55.970: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Nov 16 14:22:13.968: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceed., 1)x(UNKNOWN_MESSAGE_TYPE (5)
*Nov 16 14:22:13.968: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Nov 16 14:22:13.968: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.16.250.20:5246
remote AP dropping
According to the "sh logs" and "sh version" the AP is restarting due to power reset.  How is the AP powered?  Power brick or power injector?
remote AP dropping
After testing, it turns out the issue was a broadband router issue, pings were fine, VPN tunnels fine, but the wireless would  not register with the controller. When router was replaced the wireless registers with the controller.
13307
