Resetting Excluded Clients
Hi All,
I'm afraid I may well be asking something that is fairly simply, the question is how do you reset excluded clients, the WLAN creation page (on WCS 6.0 at least) says in note 2 "....will require administrative override to reset excluded clients", but I have not been able to find anything in the on line help or on the Cisco Site.
As ever, any help will be welcome.
Scott
Hall of Fame Super Gold
Re: Resetting Excluded Clients
On the main menu to the left, click on the "excluded clients". You'll find a list of excluded clients and on the right, there's a blue drop down link. Hover the mouse on it and choose Remove.
Hope this helps.
Hi Leo,
Thanks but that must be for an earlier version - I'm running WCS6.0.
Scott
Found it!
from the on line help......
"Monitor Client > > Select a Command
The Select a command functions can be accessed from the Client Details window.
You can access client details from the Monitor > Clients window in the following ways:
Perform a client search using the applicable search parameters. For more information on performing a client search, see "Monitoring Client Details." -OR-
Click the applicable client from the User Name column.
From the Select a command drop-down menu, the following actions can be performed:
Running a Client Link Test
Receiving Radio Measurements for a Client
Viewing Client V5 Statistics
Note This selection is only available for CCX v5 and higher clients.
Disabling a Current Client
Removing a Current Client
Enabling Mirror Mode
Viewing a Map (High Resolution) of a Client's Recent Location
Viewing a Map (High Resolution) of a Client's Current Location
Viewing an Access Point Association History Graph
Viewing an Access Point Association History Table
Viewing a Roam Reason Report for the Client
Viewing Detecting Access Point Details
Viewing Client Location History
Viewing Voice Metrics for a Client
Troubleshooting a Client"
1650
