Rogue AP on LAN, PI/MSE/WLC
I want to configure the Rogue AP detection, PI must automatic shutdown switch ports to which rogue AP connected.  Attached is a document with my current configuration. For test purpose I am using home router (TP-link). It is connected to the same switches as Rogue Detector AP:
interface FastEthernet0/33 (Rogue AP on customer port)
description FREE
switchport access vlan 15
switchport mode access
switchport voice vlan 11
switchport port-security maximum 2
switchport port-security mac-address sticky
switchport port-security mac-address sticky c04a.00e9.29cd
no logging event link-status
no snmp trap link-status
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input AutoQoS-Police-CiscoPhone
interface FastEthernet0/17 (Rogue Detector)
description AP-G2-55 Monitor
switchport trunk native vlan 30
switchport trunk allowed vlan 2,5,7-9,11,13-15,25,26,29,30
switchport mode trunk
MAC address of the router Ethernet port:
c04a.00e9.29cd
WLC see rogue AP with MAC:
c0:4a:00:e9:29:cc
(http://www.cisco.com/c/en/us/td/docs/wireless/technology/roguedetection_deploy/Rogue_Detection.html
Rogue Detector AP
A rogue detector AP aims to correlate rogue information heard over the air with ARP information obtained from the wired network. A positive match is based on the wired and wireless MAC address with difference of +1/-1. If a MAC address is heard over the air as a rogue AP or client and is also heard on the wired network, then the rogue is determined to be on the wired network. If the rogue is detected to be on the wired network, then the alarm severity for that rogue AP is raised to "Critical". It should be noted that a rogue detector AP is not successful at identifying rogue clients behind a device using NAT.)
But WLC think, that there is no rogue AP on wired network (screenshot).
Somebody have any idea?
Everyone's tags (3)
1 REPLY
https://tools.cisco.com
https://tools.cisco.com/bugsearch/bug/CSCue09354 may be this is root of problem, when I use native vlan on access port WLC can found rogue ap on wired network... but i use version 7.4.121
229
