Rogue detection with Prime 2.1
Hi@all,
i know many questions in the last days, but i must say, the last WCS works better as the compination Prime 2.1 and 5760 ;).
My problem, we have a huge campus and at peaks ~ 1500 rogue-aps.
In my new configuration (2x 5760 and Prime 2.1), the wlc see the rogue-aps but in the security dashboard at the prime no rogue are listet.
The 5760 are in the same mobility/rf-group, the polling interval at the Prime are 15 minutes.
Maybe some one has a similar problem and could help.
regards
  René
1 ACCEPTED SOLUTION
VIP Purple
HiDo you see the rogue AP on
Do you see the rogue AP on 5760 itself ? "show wireless wps rogue ap summary" output shows you the identified rogue APs. If you can't see anything there, then you may not enable Rogue AP detection on your controller. See whether in your 5760 configuration, the first line below is configured (which will enable rogue detection). Second line is to increase the threshold to minimize false detection. Refer 5760 RRM config guide for more details.
wireless wps ap-authentication
wireless wps ap-authentication threshold 50
This document describe some of the best practices of 5760 configuration including rogue detection as well.
Cisco 5760 IOS Wireless LAN Controller Configuration Best Practices
Rasika
**** Pls rate all useful responses ****
VIP Purple
Rasika
Hi Rasika, Both 5760 see the
Hi Rasika,
Both 5760 see the rogue AP but in Prime they aren't shown.
WLC-1#sh wireless wps rogue ap summary
Rogue Location Discovery Protocol            : Enabled
Rogue on wire Auto-Contain                   : Disabled
Rogue using our SSID Auto-Contain            : Disabled
Valid client on rogue AP Auto-Contain        : Disabled
Rogue AP timeout                             : 1200
Rogue Detection Report Interval              : 10
Rogue AP minimum RSSI                        : -128
Rogue AP minimum transient time              : 0
Number of rogue APs detected : 206
MAC Address         Classification     # APs    # Clients   Last Heard
0002.6fe9.46f7      Unclassified       6        0           Fri Sep  5 08:22:09 2014
Kind regards
  René
Ok, maybe the failure was the
Ok, maybe the failure was the ap-autentication, because my setting was:
wireless wps none.
I have changed and now he shows the rogue APs in Prime.
Thx
VIP Purple
Glad to hear that :)
Ok, it  won't work.  First he
Ok, it  won't work.
First he reported the correct amount of rogue to the Prime.  30min later he stoped, so at the moment we have again 0 reported rogue AP. But the mse see ~300.
VIP Purple
HiIf it is not working with
If it is not working with consistent behavior, I think you should reach TAC. They may know some specifics for these
Rasika
I have open an TAC. Thx for
I have open an TAC. Thx for your help.
123
