Rogues? What Rogues?
Hi All,
As I type the WCS Home page is reporting that I have a total of 59 rogue APs in the 'Rogue Detail Summary" table. However, when I click on the red underlined '59' WCS takes me to the rogue AP page and, guess what, the page is blank! Up until a few days ago this page was working ok. Has anybody else came across this?
Any help as ever will be greatly appreciated.
Cheers,
Scott
Re: Rogues? What Rogues?
What rev of wcs, wlc and location app are you running? Also, what are the setting under Adminstration|Settings in WCS?
Hi Eric,
Thanks for your help
WCS is 5.0.56.0
WLCs are 5.0.148.0
no location appliances
The settings in admin/settings should all be at the defaults as I have not made any changes to them. However....
Data Management 31, 31, 10, 31
Report "filepath", 31
Mail Server - all blank except 'From' - WCS@"WCSIP"
Login Disclaimer - Blank
Alarms unchecked, checked, unchecked
Client unchecked
Notification Receiver - None
SNMP unchecked, Exponential, checked, 2, 2, 100
Also, if I click on the number of adhoc Rogues on the Home page then that table displays OK.
The alarm summary table in the bottom left of the browser widow displays 0 rogues when the table on the Home page says 60.
Scott
Hmmm.... I have not moved up to 5x yet, so I may not be of much help.
Are you running WCS on Linux or windows? Have you restarted the service or rebooted since?
It almost sounds like a bug. See CSCsk17031
CSCsl51188, CSCsl53612, CSCsl98668 from http://www.cisco.com/en/US/docs/wireless/wcs/release/notes/WCS_RN5_0.html#wp44532
Hi Eric,
Its a Linux system.
I tried restarting the service and rebooting - neither made any difference I'm afraid.
Thanks for trying
Scott.
I've discovered I can get to the expected data if I select 'Monitor','Security'the click on the number of "Unclassified Rogues".
It sounds like a bug indeed.
Scott
140
