Routed network using VRF and WLC Webaccess for Guest LAN
I have a guest lan that uses a seperate VRF on my network. That guest LAN needs to get services and access the internet via the WLC.
I cannot assign an IP address on the ingress port of the WLC which doesn't allow me to setup an IP-Helper or a next hop for traffic via the WLC. Since the ingress and egress are on different vlan's somehow i need to route the traffic to the egress.
Using the VRF doesn't allow me to create a route like "ip route VRF Guest 0.0.0.0 0.0.0.0 gig 1/5" or "ip route VRF Guest 0.0.0.0 0.0.0.0 vlan 5"
Any ideas?
Everyone's tags (6)
1 REPLY
Does the L3 interface on your router or L3 switch look anything like this?
interface Vlan119
description GUEST VLAN
ip vrf forwarding GUEST
ip address 172.16.254.2 255.255.252.0
ip helper-address 172.16.255.1
no ip redirects
no ip proxy-arp
glbp 119 ip 172.16.254.1
glbp 119 timers 2 7
glbp 119 priority 150
glbp 119 preempt delay minimum 600
glbp 119 authentication md5 key-string 7 1326431F1B1917232203
glbp 119 forwarder preempt delay minimum 3600
load-interval 30
end
This is an edited version of an L3 interface in a 6509 hosting a WiSM.  The WiSM guest interface is in this subnet.  The helper points to NAC.  Clients in this subnet are NAT'd to public IPs when heading out to the Internet.
4007
