Scaling guest network with wlc
We currently have a guest network available, and we are growing at a rate where the subnet I have is not large enouph to handle all of the users on the guest network.  Without creating a separate WLAN and attaching it to another subnet is there any way I can have one WLAN (GUEST-WIFI) and have it tunnel back to the controller but still have separate subnets for various buildings like I have with H-REAP?
If not what is my alternative for setting up a guest larger guest network?  Standard WLAN's, and manually trunk separate vlans back to the controller?
Dan.
1 ACCEPTED SOLUTION
Re: Scaling guest network with wlc
Hi Dan,
this is pretty easily achievable. The feature is called "AP groups". Check in the "WLAN" tab.
You can create groups of APs and each group can have a different mapping SSID-interface.
So for each group you will be able to decide what will be the interface for SSID guest.
You can then do it building-based or floor-based if you want to .
Hope this helps,
Nicolas
Don't forget to rate answers that you find useful
Hi Dan,
Hope this helps,
Nicolas
Ah, I knew it would be possible.  Thanks.
200
