Community Member
Separating Management from Data traffic on AIR-AP1131AGs
HI all,
I am trying to redesign the network in my place of employment.  When I got here, all traffic was contained on one vlan and address space was a real issue.  As we have moved forward, we are beginning to rectify this issue.  I am moving all management traffic onto a separate vlan.  This has been working well, up to the point where I try to get these AIR-AP1131AGs configured.
I discovered, through the web ui that you can assign vlan's to the SSID's (which is exactly what I want to do).  After setting this up, i did not see how to define the management vlan.  my desire is that the ap should be ip'ed in the management vlan and pass traffic in the data vlan.  Seems like a simple request but I have not figured out how it make it happen.
I thought perhaps default vlan (define the data vlan using the webui, then define all untagged traffic as belonging to the management vlan).  I am not sure how to accomplish this as the ap connects to an third-party vendor's gear (Extreme x450e stack).
Any help would be greatly appreciated.
-Ronnie
Community Member
Re: Separating Management from Data traffic on AIR-AP1131AGs
I was able to get the this setup working, but not the all cisco version.  I am not sure how to ip the ap on the management vlan and pass traffic on the data vlan.
I have tried config'ing the port as a trunk and calling the native vlan on that trunk port vlan 20, but the device never replied to ping:
switchport mode trunk
switchport trunk native vlan 20
I had not saved the config on the ap, so I was able to restore the config settings on the port and bounce the port:
switchport mode access
switchport access vlan 10
As a refresher, I have an AIR-AP1131AG that is attached to a 3560-24.  the switch is on the management vlan and I can telnet into it, which I believe confirms that routing is correct and that the vlans are present and configured in each upstream device.  Please advise.
-Ronnie
Community Member
I was able to get this working.  If someone else happens across the same issue, here is what I did to resolve it:
Relevant config on the ap,
dot11 vlan-name Legacy_data vlan 10
dot11 vlan-name Ntwk_Mgmt vlan 20
dot11 ssid
   vlan 10
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 10 mode ciphers aes-ccm tkip
ssid
station-role root
interface Dot11Radio0.10
encapsulation dot1Q 10
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.10
no ip route-cache
bridge-group 10
interface FastEthernet0.20
no ip route-cache
bridge-group 1
interface BVI1
ip address
no ip route-cache
and on the switch:
interface FastEthernet0/16
398
