Setting Alarm in case Aeroscout Engine goes down
Hey
I am looking for a way to set up an alarm through WCS if the Aeroscout engine running on the MSE 3350 goes down. In other words if the registered/active status of the Aeroscout CLE goes false/false or true/false, I should be notified?
Thanks !
1 REPLY
Re: Setting Alarm in case Aeroscout Engine goes down
You may be able to get an alarm set up for the MSE, but I'm not sure about the Aeroscout Engine. You may have better luck setting up a notification in your monitoring system..
315
