setting internal dhcp server on 5508 wireless controller for Access Points!
Hi!
Can someone tell me how to setup the internal dhcp server on the cisco 5508 (ver 7.3 code) to provision IP addresses to access points connecting to it (via L2 switch)? There will be about 25 APs. Here is what I have configured via the GUI:
1) set the management interface with an IP and gw.
2) enabled the management interface for dynamic ap management
3) port 1 of the controller set as untagged.
4) dhcp server under management interface configured to be the same IP as the management interface.
5) dhcp scope defined and management interface set as the gateway. dhcp enabled after defining scope.
6) dhcp proxy enabled
Even connecting a PC to port 1 doesn't give the PC an IP address from the controller.
Any help would be much appreciated. Always found cisco wireless controller configs to be obtuse!
Silver
This is a step by step guide
This is a step by step guide for configuring internal DHCP server in 5508
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/110865-dhcp-wlc.html
Bronze
Hi,please go through this
please go through this document link for code 7.3 internal DHCP configuration
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-3/configuration/guide/b_cg73/b_wlc-cg_chapter_0111.html#ID356
Gold
Cisco WLC 5508 Configure
Configure WLC 5508 for Internal and Guest WLAN
Access the controller Web Console using its Management IP Address (In this case 10.20.0.10)
Below is the Steps to Configure the WLC for two SSID's with two Subnets
(1)  Under Controllers Tab --> Internal DHCP Server-->DHCP Scope
              (a) TESTZONE SCOPE --  10.20.0.50 - 10.20.0.55
                    Default Router   ----   10.20.0.1
              (b)GUESTZONE SCOPE -- 10.10.0.50 - 10.10.0.55
                   Default Router   ----   10.10.0.1
(2) Controller --> Interface
              (a)              Management - VLAN20
                                IP Address - 10.20.0.10
                                Gateway  -  10.20.0.1
                                Primary DHCP - 10.20.0.10
          Create a new interface Guest
              (b)           GuestInt - VLAN10
                              IP Address - 10.10.0.10
                             Gateway - 10.10.0.1
(3)Controller --> Interface GP
            (a)          Guest
                               Interface name  :  Guest Int
            (b)        Test
                           Interface name   :   Management
(4)WLANS --> Create New --> general
                (a)  TESTZONE --> Interface : Management
                (b) GUEST -->Interface  :  Guestint
(5)WLANS-->ADVANCED-->APGROUPS
                 (a) TESTGP-->WLANS
                             (1) TESTZONE
                              (2) TESTGUEST
613
