SHA2 certificates and WebAuth with 7.4 code
Hi All,
are SHA2 certificates supported on the 2504 and 5508, the reason is that I am doing WebAuth and the Certificate
I got from GoDaddy was an SHA1 signed by a Root CA (GO Daddy Class 2 Certification Authority Root Certificate) that
is not in the cert root store on the Android phones I am using, these phones only have the GO Daddy Root Certificate Authority - G2,
root cert in their certificate store, which only signs certificates as SHA2.
So if I get the certificate reissued will it be accepted by controller
TIA
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
So the issue was how you initially generated the certificate, or you were just asking but didn't initially try it?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Re: SHA2 certificates and WebAuth with 7.4 code
I don't believe so. Sha1 as far as I know is the only type supported.
-Scott
I got the certifcate re-keyed with SHA2, it uploaded fine to controller
and problems went away, So it looks like SHA2 works on WLC2504 with 7.4.100.0
Scott
-Scott
I had read SHA2  wasn't supported on WLC so had it signed has SHA1, but Go Daddy SHA1 root wasn't in CTL of phone.
466
