Single WLAN Controller Limitations
Aside from redundancy, are there any other limitations to deploying a single Cisco 5508 WLAN Controller that I should be aware of?   The configuration guide states you need multiple controllers for the following:
A multiple-controller system has the following additional features:
•Autodetecting and autoconfiguring RF parameters as the controllers are added to the network.
•Same-subnet (Layer 2) roaming and inter-subnet (Layer 3) roaming.
•Automatic access point failover to any redundant controller with a reduced
Is it true you can't have those roaming capabilities with a single controller?
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Single WLAN Controller Limitations
No... You have all those except for redundancy.
Sent from my iPhone
-Scott
1 REPLY
Sent from my iPhone
-Scott
523
