site survey clarifications
Hi Experts ,
could you please some clarifications on the below  questions,
1. how to do High density deployments with less interference
2. How to eliminate interference using site survey
3.Even though proper site survey is done in some of our customer sites , the AP's load / interference is showing more than 50% eventhough less number of clients is connected.
4.We are facing interference related issues , where we deployed in high dense environment.
Thanks for your time.
BR
Vijay
Everyone's tags (2)
Hall of Fame Super Gold
In a dense wireless
In a dense wireless environment, there's really nothing you can do when you have neighbors with significant wireless deployment.
You can alleviate the issue by deploying APs that support CleanAir.  But CleanAir can only help you up to a certain degree.   If, for example, one of your neighbor's AP is so close to your property and it's blasting Wi-Fi like a disco boom-box, if there are no more channels to use CleanAir could potentially lower the power to the radio that no one can connect to it via 802.11b radio.
Bronze
Hi,please check this cisco's
please check this cisco's recommended guide for dense deployement.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1250-series/design_guide_c07-693245.html
Bronze
Please refer: http://www
Please refer: http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_rrm.html
Reduce power on APs and use
Reduce power on APs and use combination of Omnis and directional (patch / sector like) antennas.
76
