Smart phone disassociate after few minutes
I have a problem here with smart phone and AIR-LAP1131AG.
Every time, my user will disassociate with the wireless after few mins of connectivity. I debug and find out:
(Cisco Controller) >*osapiBsnTimer: Nov 01 16:14:13.408: 6c:83:36:df:64:0c apfMsExpireCallback (apf_ms.c:608) Expiring Mobile!
*apfReceiveTask: Nov 01 16:14:13.408: 6c:83:36:df:64:0c apfMsExpireMobileStation (apf_ms.c:5009) Changing state for mobile 6c:83:36:df:64:0c on AP 00:26:0b:c7:c3:10 from Associated to Disassociated
*apfReceiveTask: Nov 01 16:14:13.408: 6c:83:36:df:64:0c Scheduling deletion of Mobile Station:  (callerId: 45) in 10 seconds
.......etc[in Full Debug.docx]
It's only happen with smart phones.  I have tried change the radio to B and G, previously is All. Restarted AP, but still the same
Current controller timeout:1800 seconds
Anyone please advise.
Hall of Fame Super Silver
Re: Smart phone disassociate after few minutes
Post your show WLAN and also what types of smart phones? are other devices working?
-Scott
(Cisco Controller) >show wlan 14
WLAN Identifier.................................. 14
Profile Name..................................... 4G Access by Yes
Network Name (SSID).............................. 4G Access by Yes
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 6
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ yeshotspot
Multicast Interface.............................. Not Configured
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... 802.11b and 802.11g only
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
  Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   CKIP ......................................... Disabled
   IP Security................................... Disabled
   IP Security Passthru.......................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
The smart phone is HTC One. Others devices are same.
testing
testing
great discussion
great discussion
test
test
testtest
testtest
Well you have a wide open ssid and that tells me it's 99% a client issue. Testing with an open ssid is what we do to eliminate the wireless configuration and kind of points us to the client.
-Scott
Not that agree is 99% client issue. We do another set of configuration same in Ruckus-different WLC.
The client work well without any disconnect issue.
Anyway to drill down the problem?
Debug your client and see what the debug shows.
-Scott
Debug client results as below:
Cisco Controller) >*DHCP Proxy DTL Recv Task: Oct 25 16:31:41.526: DHCP discarding packet -- IP protocol invalid (6)
*osapiBsnTimer: Oct 25 16:47:09.881: e8:99:c4:a5:8b:f4 apfMsExpireCallback (apf_ ms.c:608) Expiring Mobile!
*apfReceiveTask: Oct 25 16:47:09.881: e8:99:c4:a5:8b:f4 apfMsExpireMobileStation(apf_ms.c:5009) Changing state for mobile e8:99:c4:a5:8b:f4 on AP 0c:d9:96:01:6 2:b0 from Associated to Disassociated
*apfReceiveTask: Oct 25 16:47:09.881: e8:99:c4:a5:8b:f4 Scheduling deletion of Mobile Station:  (callerId: 45) in 10 seconds
*osapiBsnTimer: Oct 25 16:47:19.881: e8:99:c4:a5:8b:f4 apfMsExpireCallback (apf_ms.c:608) Expiring Mobile!
*apfReceiveTask: Oct 25 16:47:19.882: e8:99:c4:a5:8b:f4 Sent Deauthenticate to mobile on BSSID 0c:d9:96:01:62:b0 slot 1(caller apf_ms.c:5094)
*apfReceiveTask: Oct 25 16:47:19.882: e8:99:c4:a5:8b:f4 apfMsAssoStateDec
*apfReceiveTask: Oct 25 16:47:19.882: e8:99:c4:a5:8b:f4 apfMsExpireMobileStation (apf_ms.c:5132) Changing state for mobile e8:99:c4:a5:8b:f4 on AP 0c:d9:96:01:62:b0 from Disassociated to Idle
*apfReceiveTask: Oct 25 16:47:19.882: e8:99:c4:a5:8b:f4 Scheduling deletion of Mobile Station:  (callerId: 47) in 10 seconds
*apfMsConnTask_0: Oct 25 16:47:22.658: e8:99:c4:a5:8b:f4 Association received from mobile on AP 00:26:0b:c7:7a:c0
*apfMsConnTask_0: Oct 25 16:47:22.658: e8:99:c4:a5:8b:f4 10.108.129.198 RUN (20)Changing ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1621)
*apfMsConnTask_0: Oct 25 16:47:22.658: e8:99:c4:a5:8b:f4 Applying site-specific IPv6 override for station e8:99:c4:a5:8b:f4 - vapId 14, site 'Cisco_New_Wing',interface 'yeshotspot'
*apfMsConnTask_0: Oct 25 16:47:22.658: e8:99:c4:a5:8b:f4 Applying IPv6 Interface Policy for station e8:99:c4:a5:8b:f4 - vlan 100, interface id 22, interface' yeshotspot'
*apfMsConnTask_0: Oct 25 16:47:22.658: e8:99:c4:a5:8b:f4 Applying site-specific override for station e8:99:c4:a5:8b:f4 - vapId 14, site 'Cisco_New_Wing', interface 'yeshotspot'
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 10.108.129.198 RUN (20) Changing ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1621)
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 STA - rates (8): 140 18 152 36 176 72 96 108 12 18 24 96 0 0 0 0
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 10.108.129.198 RUN (20) Deleted mobile LWAPP rule on AP [0c:d9:96:01:62:b0]
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 Updated location for station old AP 0c:d9:96:01:62:b0-1, new AP 00:26:0b:c7:7a:c0-1
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 10.108.129.198 RUN (20) Applied RADIUS override policy
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 10.108.129.198 RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  on AP 00:26:0b:c7:7a:c0, slot 1, interface = 1, QOS = 0
  ACL Id = 255, Jumbo Frames = NO
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 10.108.129.198 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 5006  IPv6 Vlan = 100, IPv6 intf id = 22
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 10.108.129.198 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 10.108.129.198 RUN (20) DHCP required on AP 00:26:0b:c7:7a:c0 vapId 14 apVapId 2for this client
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 10.108.129.198 RUN (20)Plumbed mobile LWAPP rule on AP 00:26:0b:c7:7a:c0 vapId 14 apVapId 2
*apfMsConnTask_0: Oct 25 16:47:22.659: e8:99:c4:a5:8b:f4 10.108.129.198 RUN (20)Change state to RUN (20) last state RUN (20)
*apfMsConnTask_0: Oct 25 16:47:22.660: e8:99:c4:a5:8b:f4 apfMsAssoStateInc
*apfMsConnTask_0: Oct 25 16:47:22.660: e8:99:c4:a5:8b:f4 apfPemAddUser2 (apf_policy.c:223) Changing state for mobile e8:99:c4:a5:8b:f4 on AP 00:26:0b:c7:7a:c0  from Idle to Associated
*apfMsConnTask_0: Oct 25 16:47:22.660: e8:99:c4:a5:8b:f4 Scheduling deletion of  Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_0: Oct 25 16:47:22.660: e8:99:c4:a5:8b:f4 Sending Assoc Response to station on BSSID 00:26:0b:c7:7a:c0 (status 0) ApVapId 2 Slot 1
*apfMsConnTask_0: Oct 25 16:47:22.660: e8:99:c4:a5:8b:f4 apfProcessAssocReq (apf _80211.c:5241) Changing state for mobile e8:99:c4:a5:8b:f4 on AP 00:26:0b:c7:7a:c0 from Associated to Associated
*pemReceiveTask: Oct 25 16:47:22.664: e8:99:c4:a5:8b:f4 10.108.129.198 Removed NPU entry.
*pemReceiveTask: Oct 25 16:47:22.669: e8:99:c4:a5:8b:f4 10.108.129.198 Added NPU entry of type 1, dtlFlags 0x0
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.150: e8:99:c4:a5:8b:f4 DHCP received  op BOOTREQUEST (1) (len 322,vlan 0, port 1, encap 0xec03)
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.151: e8:99:c4:a5:8b:f4 DHCP processing DHCP REQUEST (3)
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.151: e8:99:c4:a5:8b:f4 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 0
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.151: e8:99:c4:a5:8b:f4 DHCP   xid: 0x93845604 (2474923524), secs: 0, flags: 0
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.151: e8:99:c4:a5:8b:f4 DHCP   chaddr: e8:99:c4:a5:8b:f4
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.152: e8:99:c4:a5:8b:f4 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.152: e8:99:c4:a5:8b:f4 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.152: e8:99:c4:a5:8b:f4 DHCP   requested ip: 10.108.129.198
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.153: e8:99:c4:a5:8b:f4 DHCP successfully bridged packet to DS
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.197: e8:99:c4:a5:8b:f4 DHCP received op BOOTREPLY (2) (len 308,vlan 100, port 1, encap 0xec00)
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.197: e8:99:c4:a5:8b:f4 DHCP processing DHCP ACK (5)
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.197: e8:99:c4:a5:8b:f4 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.197: e8:99:c4:a5:8b:f4 DHCP   xid: 0x93845604 (2474923524), secs: 0, flags: 0
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.198: e8:99:c4:a5:8b:f4 DHCP   chaddr: e8:99:c4:a5:8b:f4
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.198: e8:99:c4:a5:8b:f4 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.108.129.198
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.198: e8:99:c4:a5:8b:f4 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Proxy DTL Recv Task: Oct 25 16:47:23.198: e8:99:c4:a5:8b:f4 DHCP   server  id: 10.108.129.1  rcvd server id: 10.108.129.1
Hall of Fame Super Gold
Can you ping this IP address?
Post the output to the command "sh client detail e8:99:c4:a5:8b:f4" about 20 seconds after the authentication.
Please refer below result:
(Cisco Controller) >ping 10.108.129.198
Send count=3, Receive count=3 from 10.108.129.198
(Cisco Controller) >show client detail e8:99:c4:a5:8b:f4
Client MAC Address............................... e8:99:c4:a5:8b:f4
Client Username ................................. N/A
AP MAC Address................................... 0c:d9:96:01:62:b0
AP Name.......................................... APd48c.b53c.570a
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 14
BSSID............................................ 0c:d9:96:01:62:b1
Connected For ................................... 387 secs
Channel.......................................... 9
IP Address....................................... 10.108.129.198
Association Id................................... 184
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Client CCX version............................... 4
Client E2E version............................... No E2E support
Mirroring........................................ Disabled
QoS Level........................................ Silver
802.1P Priority Tag.............................. disabled
WMM Support...................................... Enabled
Power Save....................................... ON
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,
    ............................................. 12.0,18.0,24.0,36.0,48.0,
    ............................................. 54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
ACL Name......................................... none
ACL Applied Status............................... Unavailable
NPU Fast Fast Notified........................... Yes
Policy Type...................................... N/A
Encryption Cipher................................ None
Management Frame Protection...................... No
EAP Type......................................... Unknown
VLAN............................................. 100
Quarantine VLAN.................................. 0
Access VLAN...................................... 100
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 10
      Fast BSS Transition........................ Not implemented
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 0
      Number of Bytes Sent....................... 0
      Number of Packets Received................. 0
      Number of Packets Sent..................... 0
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Key Msg Timeouts............. 0
      Number of Data Retries..................... 0
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 0
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ Unavailable
      Signal to Noise Ratio...................... Unavailable
Nearby AP Statistics:
      AP0025.45af.e3f8(slot 0) ..................
antenna0: 242 seconds ago -128 dBm............... antenna1: 206 seconds ago -93 dBm
      AP442b.0314.ec7a(slot 0) ..................
antenna0: 132 seconds ago -95 dBm................ antenna1: 132 seconds ago -92 dBm
      APd48c.b53c.570a(slot 0) ..................
antenna0: 18 seconds ago -80 dBm................. antenna1: 18 seconds ago -77 dBm
      APd48c.b53c.570a(slot 1) ..................
antenna0: 579 seconds ago -82 dBm................ antenna1: 579 seconds ago -81 dBm
      APd48c.b561.1a94(slot 0) ..................
antenna0: 132 seconds ago -74 dBm................ antenna1: 132 seconds ago -79 dBm
Please comment. Thanks
According to the output you've furnished, the signal seen by the AP is really, really bad.
The user is sit under APd48c.b53c.570a, the current AP tx power is :
Tx Power
      Num Of Supported Power Levels ............. 7
      Tx Power Level 1 .......................... 17 dBm
      Tx Power Level 2 .......................... 14 dBm
      Tx Power Level 3 .......................... 11 dBm
      Tx Power Level 4 .......................... 8 dBm
      Tx Power Level 5 .......................... 5 dBm
      Tx Power Level 6 .......................... 2 dBm
      Tx Power Level 7 .......................... -1 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 1
Will it help if lower down the power?
It doesn't matter where the client sit.  The main thing to consider is the wireless NIC cards make the decision what AP to join.
What is the brand and model of your wireless NIC card.  If this is Intel, is the wireless card up-to-date?
It's happen in most of the smartphone and gadget.
And only to smartphones and tablets?  What about laptops/netbooks?
Yes, is same in laptop and tablet.
So let me get this straight:  This issue is affecting ALL wireless clients?
And I think I know why.  Can you enable all radios:  802.11 a/b/g/n
Try this out.
Previously is all radio and I get the same problem, so I change to only b/g to tried but still no luck
Draw the layout of your site, the location of the APs and the location of the affected wireless clients.
There's something you're not telling us.
The signal strengths you've posted is showing the client has LOW WIRELESS SIGNAL, however, all your posts doesn't seem to describe distances as well as obstacles between the wireless clients and the APs.
Next, you are saying this issue is affecting all users but your opening thread is all pointing to a single wireless client (but then you've said it's only affecting all "smart phones").
749
