SNMP management on AP350
I have configured SNMP, it is enabled and the RO community is set. But from the management machine, I try to send "gets" or "snmpwalk" to the AP350 and it doesn't respond.
Does anyone know what could be the problem?
1 ACCEPTED SOLUTION
Blue
Re: SNMP management on AP350
What rights are enabled for this AP for the SNMP user that you have created as the string?
Blue
Ok. Your suggestion fixed the problem. We needed a username with the community string and SNMP rights.
Regards.
159
