SNMP OIDs for Cisco AP
Good day!
I am just testing the SNMP trap received from controller to see the diffference between the status change on AP.
I find that it is strange to receive a SNMP trap with an OID: 1.3.6.1.4.1.9.9.513.0.10 as table below when I turned off the radio interface. It is because this notification is generated when AP's Interface operational status goes up.  But actually, I have turned it down. Is it normal to receive a "UP" log?
Also, when I turned on the radio interface again, it sent out 3 SNMP traps in once, the pattern is “Up”, “Down”, then “Up”. Is there any explanation on this?
Received trap right after turn off Radio InterfaceReceived traps right after turn on Radio Interface
======= ciscoLwappApIfUpNotify =======
Trap Oid : 1.3.6.1.4.1.9.9.513.0.10
Trap time : Fri Aug 16 11:15:45 HKT 2013
oid: 1.3.6.1.2.1.1.3.0 | value: 57 days, 18:24:22.00
oid: 1.3.6.1.6.3.1.1.4.1.0 | value: 1.3.6.1.4.1.9.9.513.0.10
oid: 1.3.6.1.4.1.9.9.513.1.1.1.1.1.0 | value: d0:c7:89:c6:6a:40
oid: 1.3.6.1.4.1.9.9.513.1.2.1.1.1.0 | value: 0
oid: 1.3.6.1.4.1.9.9.513.1.1.1.1.39.0 | value: 13
oid: 1.3.6.1.4.1.9.9.513.3.8.0 | value: 2
oid: 1.3.6.1.4.1.9.9.513.3.9.0 | value: Radio Admin State Change
oid: 1.3.6.1.4.1.9.9.513.3.10.0 | value: AP_IF_TRAP_CONFIG_RADIO
oid: 1.3.6.1.4.1.9.9.513.1.1.1.1.5.0 | value: Testing_AP_5F_LHK
AP-Name: Testing_AP_5F_LHK
Ignore SNNP Trap (Corresponding Event not found)
Trap time : Fri Aug 16 11:17:33 HKT 2013
oid: 1.3.6.1.2.1.1.3.0 | value: 57 days, 18:26:09.00
======= ciscoLwappApIfDownNotify =======
Trap Oid : 1.3.6.1.4.1.9.9.513.0.11
oid: 1.3.6.1.6.3.1.1.4.1.0 | value: 1.3.6.1.4.1.9.9.513.0.11
oid: 1.3.6.1.4.1.9.9.513.1.1.1.1.38.0 | value: 1
oid: 1.3.6.1.4.1.9.9.513.1.2.1.1.14.0 | value: 1
oid: 1.3.6.1.4.1.9.9.513.3.9.0 | value: Radio interface reset.
oid: 1.3.6.1.4.1.9.9.513.3.10.0 | value: RADIO_RC_IDB_RESET
Event Created [AP's Interface operational status goes down]
Trap time : Fri Aug 16 11:17:34 HKT 2013
oid: 1.3.6.1.2.1.1.3.0 | value: 57 days, 18:26:10.00
Event Closed [1988089|AP's Interface operational status goes down]
Lots of thanks for advices!
1333
