Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
SSID Connection Problems with multiple VLANs
Hello all,
I'm having a bit of a problem getting a device to associate to an access point and grab an IP via DHCP on a particular SSID. This access point has two VLANs, with two different SSIDs configured. Enclosed is the configuration. For some reason I cannot connect to SSID 2 on my wireless device, but SSID works just fine. I see the authentication go through the log, so I know that the pre-shared key is correct, but it can't grab an IP (which makes me think I have a problem in the bridge group). Any thoughts?
Also, I have tried both a trunk port and an access port on the switch that is connected to the access point. With both, I can connect and grab an IP from VLAN 20 (SSID 1), but not VLAN 10 (SSID 2).
dot11 ssid 1
vlan 20
authentication open
authentication key-management wpa
wpa-psk ascii "key"
dot11 ssid 2
vlan 10
authentication open
guest-mode
wpa-psk ascii "key"
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
encryption vlan 20 mode ciphers tkip
encryption vlan 10 mode ciphers tkip
ssid 1
ssid 2
antenna transmit right
antenna receive right
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.10
encapsulation dot1Q 10
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.10
encapsulation dot1Q 10 native
no ip route-cache
bridge-group 1
interface FastEthernet0.20
no ip route-cache
bridge-group 20
interface BVI1
ip address 192.168.0.210 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.1
bridge 1 route ip
Thanks for your help!
1 ACCEPTED SOLUTION
Gold
Re: SSID Connection Problems with multiple VLANs
Your bridge-groups are not lining up. You have VLAN 10 mapped to bridge-group 1 on the FastEthernet interface but mapped to bridge-group 10 on the radio. Just remove bridge-group 1 from the main radio interface and apply it to the dot0.10 subinterface.
Gold
That did it.
Thanks for your help.
It's funny because they did originally line up. Bridge-group 1 was on the main interface and the radio interface, with 10 on vlan 10 and 20 on vlan 20. But when I set the 0.10 subinterface to native it must have trumped the #1 bridge-group and I didn't realize it.
I was held up on this originally because I couldn't remove bridge-group 1 from the start, but now I can connect on both SSIDs and grab DHCP IPs from the different subnets. Thanks again.
257
