SSID will not Broadcast
I currently have a 5508 with ver 7.4 running 3500 and 3600 series AP. I have 3 SSID's on the controller already with one broadcasting. They are on WLAN 1, 2, 3. When I try to add a new WLAN I am unable to get it to broadcast the SSID. I have the WLAN enabled and I have the Broadcast SSID enabled. I have tried deleting and recreating the new SSID and still unable to get it to broadcast. If I enable one of the non broadcasting SSIDs I currently have on the WLC it will broadcast. It seems to just be any new WLANS that have the broadcast issue. Anyone have any ideas?
David
Re: SSID will not Broadcast
Is the WLAN in the AP group associated to the AP?
That was it......Thanks Man.....
As told please check whether WLAN is in the same AP group associated with AP’s.
Please do not forget to mark as answered if your query is resolved.
140
