strange behaviour migrating from wcs to ncs
hi
the setup is:
1 primary controller + 1 secondary controller
1 primary legacy controller + 1 secondary legacy
after connecting the primary legacy controller to ncs all ap's connected to it moved to the primary controller
ap configuration is
1-primary legacy
2- primary
what the hell is happening?
why ap's migrated to primary controller (which is the second choice)?
I tryed rebooting one of them and it connected again to primary contr.
someone has its own opinion to share?
Everyone's tags (5)
Hall of Fame Super Silver
Re: strange behaviour migrating from wcs to ncs
I would make sure master controller is not enabled on the wlc that the APs are joining. Also make sure that the APs have the primary, secondary and or tertiary wlc (hostname is case sensitive an must math the wlc system name) configured correctly an ap fallback is enabled. Make sure that the mobility groups are correct also, seems like a configuration on the wlc could of changed.
-Scott
I will check thanks but I cannot understand why something could have changed...
may it be that the primary legacy is now both under wcs and ncs?
this is making me mad...
Well... The data was migrated. So is it 100% fool proof... sometimes but not always:) I guess it's something I have learned from experience. Sometimes it goes well and sometimes not so well. Now I don't know what has changed, but it's something you will have to make sure you fix so that WCS doesn't push it out again.
-Scott
thanks scott for your suggestions
I managed to solve the issue, it was not an ncs problem... for some unknown reason the trunk connecting the controller to the ap vlan went down (deleted)...
now all is normal tahk you
Thanks for the follow up. Good to know it wasn't the migration:)
-Scott
379
