Sudden high CPU utilization on Cisco AIR 1142
Five Cisco 1142 integrated in WDS infrastructure: 4 - AP, 1 - WDS with AP... At once on all access points loading of the processor increased to 100 %. And "show proc cpu" - in total in norm, log on all cisco identical below:
(Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1))
Start problem...
Jun 25 16:11:58: %DOT11-6-ROAMED: Station f0cb.a123.d6f9 Roamed to 0c85.257f.05d0
Jun 25 16:11:58: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f0cb.a123.d6f9 Reason: Sending station has left the BSS
Jun 25 16:23:36: %LEAPCL-3-TIMEOUT: AP Timed out authenticating to the WDS
Jun 25 16:23:42: %WLCCP_AP-6-INFRA: WLCCP Infrastructure Authenticated
Jun 25 16:23:44: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station a088.b405.7320
Jun 25 16:23:44: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 0021.5dbf.a3da
Jun 25 16:23:44: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 00f4.b91b.84cf
Jun 25 16:23:44: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0cdf.a441.1ec1
Jun 25 16:23:44: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SPB-AP1-2 0021.5dbf.a3da Associated KEY_MGMT[WPAv2-CP]
Jun 25 16:23:44: %DOT11-6-ASSOC: Interface Dot11Radio1, Station NBSPDSTAF2 a088.b405.7320 Associated KEY_MGMT[WPAv2-CP]
Jun 25 16:23:45: %WLCCP_AP-6-INFRA: WLCCP Infrastructure Authenticated
End problem...
Jun 25 16:57:26: %WLCCP_AP-6-INFRA: WLCCP Infrastructure Authenticated
Jun 25 16:57:50: %DOT11-6-ASSOC: Interface Dot11Radio1, Station NBSPDSTAF2 a088.b405.7320 Associated KEY_MGMT[WPAv2]
Jun 25 16:57:55: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station a088.b405.7320
Jun 25 16:57:55: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station a00b.bad6.949c
Jun 25 16:57:55: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0cdf.a441.1ec1
Jun 25 16:57:56: %WLCCP_AP-6-INFRA: WLCCP Infrastructure Authenticated
Jun 25 17:00:52: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   00f4.b91b.84cf Reassociated KEY_MGMT[WPAv2 PSK]
Jun 25 17:02:57: %DOT11-6-ROAMED: Station 00f4.b91b.84cf Roamed to 0c85.257f.05d0
Jun 25 17:02:57: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 00f4.b91b.84cf Reason: Sending station has left the BSS
Jun 25 17:04:12: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   00f4.b91b.84cf Associated KEY_MGMT[WPAv2 PSK]
Jun 25 17:05:10: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SPB-AP1-2 0021.5dbf.a3da Associated KEY_MGMT[WPAv2]
Jun 25 17:05:24: %DOT11-6-ASSOC: Interface Dot11Radio1, Station SPB-AP1-2 0024.d60f.30fe Associated KEY_MGMT[WPAv2]
Jun 25 17:05:40: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 0024.d60f.30fe Reason: Sending station has left the BSS
Jun 25 17:05:40: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SPB-AP1-2 0024.d60f.30fe Associated KEY_MGMT[WPAv2]
Jun 25 17:06:11: %DOT11-6-ROAMED: Station 0024.d60f.30fe Roamed to 0c85.257f.1240
The problem suddenly began, proceeded about an hour and also suddenly ended...
Somebody faced such problem?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Sudden high CPU utilization on Cisco AIR 1142
oops!
sorry. I did not recognize the K9w8!! autonomous APs should be K9w7.
I picked this from the IOS Software field of the AP download! but it seems all of the listed APs there are k9w8!! Strange!!!!
It seems I should stop right here because when I am writing something I wright something wrong! :-\
Sorry once again for not giving an answer to your concerns.
Amjad
Rating useful replies is more useful than saying "Thank you"
Can you provide me the show tech from a sample AP
Look the attached files (today "show tech", when no problem with network. If problem start again, I will show the new "show tech")
Have you made any changes lately to your network before the problem to appear?
Are all APs on same switch?
Having all APs with high CPU utilization I think there would probably be some kind of broadcast/multicast traffic that is overwhelming the APs.
Because WLCCP is a multicast protocol that would be related.
I sugges that you take a sniffer capture to monitor if there is high traffic reach the AP during the problem.
Amjad
Wasn't any changes in a configuration (before & after problem).
Yes, all APs on same switch 2960S.
Bcast/Mcast on the Interface Gig0 AP? On switch 2960S following port configuration & statistic:
Current configuration : 311 bytes
interface GigabitEthernet1/0/1
switchport trunk native vlan 4094
switchport trunk allowed vlan 33,101,1101,4094
switchport mode trunk
switchport nonegotiate
ip arp inspection trust
storm-control broadcast level 10.00
storm-control action trap
spanning-tree portfast trunk
ip dhcp snooping trust
end
SPB-ASW1-6#sh int g1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is a0cf.5b86.b901 (bia a0cf.5b86.b901)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:02, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6571
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 19000 bits/sec, 20 packets/sec
  5 minute output rate 322000 bits/sec, 90 packets/sec
     74867571 packets input, 21080606319 bytes, 0 no buffer
     Received 3704134 broadcasts (2994457 multicasts)
     0 watchdog, 2994457 multicast, 0 pause input
     1251440987 packets output, 546451442739 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Why on AP int G0 mcast = 0 ??
SPB-AP1-1#sh int g0
GigabitEthernet0 is up, line protocol is up
  Hardware is PowerPC405ex Ethernet, address is 2894.0f01.2e48 (bia 2894.0f01.2e48)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Full-duplex, 1000Mb/s, media type is T
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/1677/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 285000 bits/sec, 150 packets/sec
  5 minute output rate 22000 bits/sec, 23 packets/sec
     9993970 packets input, 1259488774 bytes, 0 no buffer
     Received 4095894 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
     733754 packets output, 235227416 bytes, 0 underruns
     0 output errors, 0 collisions, 6 interface resets
check multicast counters under BVI interface?
is nothing..
SPB-AP1-1#sh int bvi1
BVI1 is up, line protocol is up
  Hardware is BVI, address is 2894.0f01.2e48 (bia 0c85.257f.05d0)
  Internet address is 172.20.254.33/28
  MTU 1500 bytes, BW 54000 Kbit, DLY 5000 usec,
  Last input 00:00:04, output never, output hang never
  5 minute input rate 3000 bits/sec, 3 packets/sec
  5 minute output rate 2000 bits/sec, 2 packets/sec
     68660 packets input, 9545703 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     34976 packets output, 5158395 bytes, 0 underruns
What about the WDS? it shoudl show some multicast/broadcasts?
SPB-AP1-1 - this is WDS. Similar statistics on other access points
I am sorry. I have no explanation for that.
I am also not having a parralel scenario to compare.
Anyone that has WDS scenario running can help us to compare statistics.
Amjad, thank you that responded to my problem!
Anton:
Why don't you try to upgrade your IOS? just in case it is a buggy issue?
or upgrade is not an option for you?
I can see new image released on 1st of May: 12.4.23c-JA5(ED)
WIRELESS LAN LWAPP - this is light weight IOS? But complete IOS is necessary to me
WIRELESS LAN LWAPP
c1140-k9w8-tar.124-23c.JA5.tar
01-MAY-2012 32 / 16
I already set the last release for autonom. AP
oops!
Amjad
If it is interesting to someone...
Most  likely from the general network where there are access points, there  was a lot of an unwanted entering broadcast traffic. I selected Wi-Fi in  a separate subnet and set up according to the recommendations specified  in http://www.cisco.com/en/US/tech/tk39/tk371/technologies_tech_note09186a0080093c91.shtml
Now problems aren't watched, CPU loading very low!
Thanks Anton,
That is valuable information. I hope it will be useful for other people that have same issue.
1429
