Syslog Traps by SSID
We have a large number of autonomous 1242 and 1131 APs.  There are 4 SSID on the dot11radio0 interface.  I can get the association and disassociation messages but there is no indication of the SSID in the message.
Does anyone have any tips for getting this information?
*Jul 16 20:48:08.153 EDT: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   0023.15b8.4e18 Associated KEY_MGMT[WPA PSK]
*Jul 16 21:39:09.693 EDT: %DOT11-7-AUTH_FAILED: Station 0023.15b8.4e18 Authentication failed
*Jul 16 20:54:16.014 EDT: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0023.15b8.4e18 Reason: Sending station has left the BSS
Everyone's tags (2)
1 ACCEPTED SOLUTION
Unfortunately this
Unfortunately this information cannot be retrieved.
I have never come across logs that display the information for the SSID when the client connects or disconncects in an autonomous access points nor is there an option to enable such feature.
The information is displayed as you have mentioned above.
Hope this helps!!
Ashu
Note: Please do not forget to rate the posts and accept as solutions.
1 REPLY
Unfortunately this
Hope this helps!!
Ashu
77
