Tacacs+ admin in AP1200 with IOS
We have configured admin authentication by tacacs+ and, when we access through web browser, the auth window pop-up is showed, we authenticate, and after some seconds a new window appears. And this a lot of times. There are a lot of entries in the tacacs+ server (ACS v3.1), too.
If we access by telnet, everything is Ok. (Only one authentication).
TIA
  • Security and Network Management
Silver
Re: Tacacs+ admin in AP1200 with IOS
Thank you for the link, but we have IOS-based AP1200, and the web management is quite different from Vxvorks. Do know any other link about tacacs+ administration through web with IOS-based?
TIA
I'm having the same issue. I'm running 12.2(13)JA on a 350 ap; my TACACS+ box is tac_plus running on a FreeBSD 5.1-RELEASE build.
debug aaa authentication shows:
000079: .Nov 24 21:03:32.984: AAA: parse name=tty2 idb type=-1 tty=-1
000080: .Nov 24 21:03:32.988: AAA: name=tty2 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=2 channel=0
000081: .Nov 24 21:03:32.988: AAA/MEMORY: create_user (0x93BDB8) user='NULL' ruser='NULL' ds0=0 port='tty2' rem_addr='192.168.x.x' authen_type=ASCII service=LOGIN priv=0 initial_task_id='0', vrf= (id=0)
000082: .Nov 24 21:03:32.988: AAA/AUTHEN/START (1411533082): port='tty2' list='' action=LOGIN service=LOGIN
000083: .Nov 24 21:03:32.988: AAA/AUTHEN/START (1411533082): non console login - defaults to local database
000084: .Nov 24 21:03:32.992: AAA/AUTHEN/START (1411533082): Method=LOCAL
000085: .Nov 24 21:03:32.992: AAA/AUTHEN(1411533082): Status=GETUSER
000086: .Nov 24 21:03:32.992: AAA/AUTHEN/CONT (1411533082): continue_login (user='(undef)')
000087: .Nov 24 21:03:32.992: AAA/AUTHEN(1411533082): Status=GETUSER
000088: .Nov 24 21:03:32.992: AAA/AUTHEN/CONT (1411533082): Method=LOCAL
000089: .Nov 24 21:03:32.996: AAA/AUTHEN(1411533082): Status=GETPASS
000090: .Nov 24 21:03:32.996: AAA/AUTHEN/CONT (1411533082): continue_login (user='xxxxx')
000091: .Nov 24 21:03:32.996: AAA/AUTHEN(1411533082): Status=GETPASS
000092: .Nov 24 21:03:32.996: AAA/AUTHEN/CONT (1411533082): Method=LOCAL
000093: .Nov 24 21:03:32.996: AAA/AUTHEN(1411533082): Status=PASS
000094: .Nov 24 21:03:33.112: AAA/MEMORY: free_user (0x93BDB8) user='xxxxx' ruser='NULL' port='tty2' rem_addr='192.168.x.x' authen_type=ASCII service=LOGIN priv=0 vrf= (id=0)
000095: .Nov 24 21:03:37.444: AAA: parse name=tty2 idb type=-1 tty=-1
000096: .Nov 24 21:03:37.444: AAA: name=tty2 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=2 channel=0
000097: .Nov 24 21:03:37.448: AAA/MEMORY: create_user (0x93BDB8) user='NULL' ruser='NULL' ds0=0 port='tty2' rem_addr='192.168.x.x' authen_type=ASCII service=LOGIN priv=0 initial_task_id='0', vrf= (id=0)
000098: .Nov 24 21:03:37.448: AAA/AUTHEN/START (2224183919): port='tty2' list='' action=LOGIN service=LOGIN
000099: .Nov 24 21:03:37.448: AAA/AUTHEN/START (2224183919): non console login - defaults to local database
000100: .Nov 24 21:03:37.448: AAA/AUTHEN/START (2224183919): Method=LOCAL
000101: .Nov 24 21:03:37.452: AAA/AUTHEN(2224183919): Status=GETUSER
000102: .Nov 24 21:03:37.452: AAA/AUTHEN/CONT (2224183919): continue_login (user='(undef)')
000103: .Nov 24 21:03:37.452: AAA/AUTHEN(2224183919): Status=GETUSER
000104: .Nov 24 21:03:37.452: AAA/AUTHEN/CONT (2224183919): Method=LOCAL
000105: .Nov 24 21:03:37.452: AAA/AUTHEN(2224183919): Status=GETPASS
000106: .Nov 24 21:03:37.456: AAA/AUTHEN/CONT (2224183919): continue_login (user='xxxxx')
000107: .Nov 24 21:03:37.456: AAA/AUTHEN(2224183919): Status=GETPASS
000108: .Nov 24 21:03:37.456: AAA/AUTHEN/CONT (2224183919): Method=LOCAL
000109: .Nov 24 21:03:37.456: AAA/AUTHEN(2224183919): Status=PASS
000110: .Nov 24 21:03:37.568: AAA/MEMORY: free_user (0x93BDB8) user='xxxxx' ruser='NULL' port='tty2' rem_addr='192.168.x.x' authen_type=ASCII service=LOGIN priv=0 vrf= (id=0)
137
