TACACS+ not working with 5760 WLC
Hi all,
hopefully someone can help me further.
I am currently configuring one of our 5760 WLCs and I have difficulties to get TACACS+ working.
This is the configuration (note the values are exemplary):
aaa group server tacacs+ auth_grp
  server name tacacs_server
aaa authentication banner ^
*  ! TACACS server cannot be reached at the moment !  *
aaa authentication login default group auth_grp local
aaa authentication enable default group auth_grp enable
aaa authorization exec default group auth_grp local
aaa accounting exec default start-stop group auth_grp
aaa accounting commands 15 default start-stop group auth_grp
tacacs-server directed-request
tacacs server tacacs_server
  address ipv4 10.10.10.10
  key 0 shared_secret
I have already compared this configuration to other devices where it is identical and which also successfully authenticate. I have ensured that the device has been entered in the TACACS server as an AAA client. I tested it with ACS4 as well as ACS5.
Tacacs debug on the WLC shows that the request times out.
After doing a packet capture I noticed that the WLC resets the TCP connection after the SYN,ACK from the TACACS Server.
IOS version is 3.2.2SE
Does anyone have a hint?
Patrick
Just found out myself.
Tacacs does not work, if the request is going via the Mgmt Port. I had to use the data ports.
Would be nice, if this is going to be implemented in a future release.
Patrick
Thanks Patrick for sharing the info
Rating useful replies is more useful than saying "Thank you"
897
