Third Party Certificate Question
ciscopower
Hi All,
I am planning on buying a third party cert to install on a WLC. My question is, does the "Common Name" that I include on the request for the certificate need to be an actual public domain? This is just for a guest scenario and I dont want to use the companys domain name if possible. What would I put in the request and how does that effect if the certificate will be granted?
jorge.novo
Hi Phil,
  When you say: "I am planning on buying a third party cert to install on a WLC" You mean the are you going to spend money on it, aren't you?
  Just because if you are going to use the certificates only for a guest scenario, may be a private or self signed certificate should be better.
  By the way, the commonName value only identify the "element" is nor related with you company nor related with your IP or whatever
  For example, my Self signed certificates have:
For the CA
commonName              = "Ejemplo de Autoridad Certificadora"
For the Radius Server
commonName              = "Ejemplo de Certificado de Servidor"
For the clients
commonName              = "Ejemplo de Certificado de Cliente"
This certs are used for a EAP-TLS configuracion with WLC AS5508 and several Cisco 1140 Access point
I hope this help.
George Stefanick
Hi Phil.
Nope, doesnt have to be public domain.
