Trouble with VLANs
jrodri52000
I have a second WLAN implmentation underway. We have 5 APs and a Cisco 3550 switch. I have deleted all the default vlans / ssids from the IOS AP1200 ver 12.2 and then created two new ones:
SSID GUEST associated to VLAN 10 Native
SSID Engineer associated to VLAN 11
When my clients connect to guest.Life is good. They can access the network but when they connect to Engineer they can't access the network.They can't even ping the AP. All my clients have static IPs. I did this to make sure DHCP wa sout of the trouble loop. Here is my config any ideas would be highly appreciated ...
version 12.2
no service pad
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname AP-VLAN
username xxx password xxxx
clock timezone U -8
clock summer-time U recurring
ip subnet-zero
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers ckip
encryption vlan 11 mode ciphers ckip
ssid Guest
vlan 10
authentication open
guest-mode
ssid Engineer
vlan 11
authentication open
authentication network-eap eap_methods
speed basic-1.0 2.0 5.5 11.0
rts threshold 2312
power local 50
power client 50
station-role root
interface Dot11Radio0.10
encapsulation dot1Q 10 native
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.11
encapsulation dot1Q 11
no ip route-cache
no cdp enable
bridge-group 11
bridge-group 11 subscriber-loop-control
bridge-group 11 block-unknown-source
no bridge-group 11 source-learning
no bridge-group 11 unicast-flooding
bridge-group 11 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
ntp broadcast client
interface FastEthernet0.10
no ip route-cache
bridge-group 1
interface FastEthernet0.11
no ip route-cache
bridge-group 11
interface BVI1
ip address 192.168.0.200 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory/1100
ip radius source-interface BVI1
logging facility auth
radius-server local
radius-server host x.x.0.92 auth-port 1645 acct-port 1646 key xxxx
radius-server retransmit 3
radius-server attribute 32 include-in-access-req format %h
radius-server authorization permit missing Service-Type
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 5 15
end
AP-VLAN#
5 Replies 5
jrodri52000
One more thing...If I make the ssid Engineer VLAN 11 native it works but then the guest doesn't work.
So I know my eap is setup correctly.
Any Help would be great ... thnx
With AP's doing VLAN Mapping, I take what is happening is when you map Vlan 10 or Vlan 11 to the Native, it starts working. WEll, if on your switch, your ACS (or whatever authenticates EAP) is in the Switches Native VLAN, then only clients that are mapped to that native vlan will be able to talk to the authentication server. You need a router for inter vlan communications, so Vlan 11 will not talk to Vlan 10, (VLAN 10 being mapped to the native of the switch where DHCP and ACS reside).
Also, when a client connects to an AP, there are 2 connections established. One connection is set to blocking only state. The other connection is set to blocking, with 802.1x forewarding. Once 802.1x auth is complete ,(EAP), then the other connection is set to active from blocking and the client can begin communication with the network.
rslaski
Hope that you had already solved your problem, but if not then try to create int BVI11 with empty config beneath. I am not joking. There's a misbehaviour observed with VLAN configs like this. Or try to put both user VLANs into separate non-native VLANs and leave native vlan alone.
marcbutler
Hi There
Just had a look at this. you say that the GUEST SSID associated to VLAN10 is OK. Well, under your dot11radio0 interface, there is a statement that applies to the encryption mode to be used for VLAN 11, but none for VLAN 10. Hence, it may well be that the GUEST SSID VLAN is not being encrypted and, therefore, no encryption mismatch issues, therefore all traffic passes without issue.
I have seen issues where association to the AP was fine, but could not pass traffic, as there was an encryption mismatch.
I would suggest turning off all encryption, test that. If that works, then check that the clients support the encryption method that you want to implement. But to start with, it is worth just turning on static WEP to initialise the radio interface and make sure that works.
Hope that helps
Marc
Maybe you didn't configure switch port (to which AP is connected) as a trunk, so only native VLAN traffic is passing between AP and switch?
Good luck,
Srdja
