Trying to Configure AIR-CAP3602i from WLC Not working
I posted a question similiar to this a few months back and got a repy that worked. So i tried the same thing this time but the AP is different this time.
I'm trying to change the RF Channel and Tx power level on my AIR-CAP36021-E-K9 from my WLC WISM2. I do the following;
Wireless --> 802.11 b/g/n --> Access Point --> Configure. I then select custom on both Power and Channel and make my change and then
click Save Configuration in the top righthand corner. I go back to 802.11 b/g/n select my AP and the power and channel setting have reverted back to their default selection.
Any ideas?
Anthony
Everyone's tags (4)
1 ACCEPTED SOLUTION
Apply vs save configuration
Apply sends to device.
save configuration saves controller config to flash..
Is CleanAir enabled?  It is my understanding that the radios CleanAir routines are then incharge.
Re: Trying to Configure AIR-CAP3602i from WLC Not working
what is the AP mode?
Is the issue happening with both radios? Or with b/g radio only?
Rating useful replies is more useful than saying "Thank you"
We are only looking to configure b/g/n radio's as per our site survey so i haven't done anything with the a/n.
Hall of Fame Super Gold
Did you see the "*" symbol?
No i didn't.  Screen shots below looking to have AP on Channel 6 with power 3.
After i saved config and went back into 802.11b/g/n radio values have returned to what they were originally, 1 & 3
That's odd.  And what is the firmware you are running?
Firmware Version................................. FPGA 1.6, Env 0.0, USB console 2.2
Sorry, that's not the right one.  Look for "Product Version".
Thanks David.
I feel a bit silly as I never even noticed the Apply button and was too concerned with saving my config changes that I made to the APs so I was only clicking on " Save Configuration".
So once I clicked on the Apply button it took the changes to the channel and power.
Much appreciated and thanks to everybody who replied to my question.
Anthony
Good catch David. +5.
You want to say "Thank you"?
Don't. Just rate the useful answers,
that is more useful than "Thank you".
2357
