Community Member
Turning on TKIP and MIC
How do you turn on TKIP and MIC? I am running 11.10t firmware on the AP's.
Community Member
Re: Turning on TKIP and MIC
Click on the AP radio advanced link in the main setup menu. Then look for Enhanced MIC verification for WEP and Temporal Key Integrity Protocol. You will want to change your Broadcat WEP Key rotation interval, too.
Community Member
URL:
BTW, you only need to turn on broadcast key rotation if you are using EAP.
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350brdgs/brscg/br350ch4.htm
Community Member
Important Note:
If you turn up TKIP and MIC you will not be able to authenticate to the Wireless LAN from any PocketPC device. At least not until a new Cisco Client comes out that supports this in PocketPC.
Ray
Community Member
I have now enabled TKIP and MIC, but I am getting the following message in the AP's logs: "Unsupported Authentication Algorithm". I have ACU 5.01, NDIS 8.01.06, Firmware 4.25.23. Any ideas? I appear to be working, but not sure why I am getting this message.
234
