Two factor authentication in wireless network by one-time password
is this possible? What required for this scenario?
You may need to add some
You may need to add some context or give some further info!!
My organisation implemented wireless two-factor using RSA token (OTP), and certificates for the outer method (PEAP/EAP-GTC).
If you were looking to do something similar, you would need:
Wireless controller
RADIUS appliance (we use an ACS 1121)
RSA Token Server
Supplicant compatible with EAP-GTC
If you can expand your question, I can give further details.
Thanks.
Hello, thanks for the answer
Hello, thanks for the answer.
I will try to tell in more detail that we want.
We already have the following equipment:
Cisco WLC 5508 and some ap's
Cisco ACS
Microsoft AD Server
Process of authentication of the user in a wireless network is represented to me following:
at first the user enters the registration data, then to him through SMS the one-time password comes.
Thus we don't want to use digital certificates.
Whether such scheme is possible?
It is possible to have the
It is possible to have the outer method not use digital certificates if your using PEAP. Although, the benefits of a digital certificate would enhance security...
What supplicant you use and
What supplicant you use and whether your scheme for mobile devices on the basis of iOS, windows and android works?
Bronze
Hi,Please check below
Please check below link
http://www.cisco.com/c/en/us/support/docs/security/secure-access-control-server-windows/100162-rsa-wlc-acs-config.html#sthash.J5aAchwT.dpuf
1570
