Community Member
Two WLC to the same NPS Radius (win 2008)
Hi everyone :
I have a WLC 2504 running with one SSID (authentication 802.1X to NPS radius win 2008 Server) , I have another branch with another WLC 2504.
Can I have configure the same SSID with the same NPS radiud win 2008 server in this another WLC 2504?? and How could I do it?
Claudio L.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Two WLC to the same NPS Radius (win 2008)
Yes you can. You just need to configure the other WLC WLAN settings the same, add the radius server and add the WLC as a AAA client in the radius server.
-Scott
-Scott
Community Member
Hi Scoott,
Thank you so much for your response.
I have used this guide to configure this deployment :
http://www.cisco.com/en/US/products/ps10315/products_configuration_example09186a0080bfb19a.shtml
In win 2008 server , I just only add the WLC like a new Radius Client ?
I mean ,
Frienly Name : WLC2
Address IP : 192.168.1.X
Vendor : Radius Standard
Share secret : xxxx
And That´s all, right ?
That is correct.
-Scott
Community Member
Thank you so much !!!
No problem:)
-Scott
192
