Community Member
Unable to External Redirect with wired WLAN
I'm not sure if this is a bug in the GUI or Software I have trid this in both GUI and CLI.
I'm trying to redirect a Wired WLAN to an external Web-Auth server, I'm already doing so successfully with the Wireless lan.
Here is the process :
Wlans -> [WLAN ID] -> Security -> Web Authentication > tick Over-ride Global Config -> Select External (redirect to external server) insert URL and click APPLY.
The problem is that when I press Apply and check you the settings again there has been no change, so I'm still being re-directed to the internal global server.
Anyone had this problem and have a solution for me ?
Thank in advance.
Gudmundur
Silver
Re: Unable to External Redirect with wired WLAN
I suppose you are using a controller for redirection. If that is the case check the following URL and see if the configurations are right. Refer http://cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808ed026.shtml#wirguest
Community Member
I was able to configure this in the WCS when I finshed connecting the controller to the WCS.
It's quite odd.
148
