Uninstall Cisco PEAP supplicant
Hi Sir,
I have installed Cisco PEAP supplicant when I installed Cisco 350 PCM card onto my laptop.
However, during the installation process, somehow, XP default MS-CHAP v2 is overwritten and now only Cisco PEAP using EAP_GTC appeared. Please refer to the attachment.
Tried uninstall the Cisco PEAP supplicant many times but failed.
Can anyone show me how to uninstall the Cisco PEAP supplicant?
Thanks.
-delon
1 REPLY
Re: Uninstall Cisco PEAP supplicant
Hi Delon.
I think it probably uninstalls (if you're being prompted for the reboot), but it is not removed from the control panel? If so,
can you please try the following, either trying installing the ACU again and then
uninstalling it
OR you can use regedit and remove the ACU entry from the uninstaller list in the registry.
HTH,
-Joe
557
