Upgrade my Cisco WLC 2504 to 80.100 and my AIR-LAP1141N-A-K9 radio wont enable
Upgrade my Cisco WLC 2504 to 80.100 and my AIR-LAP1141N-A-K9 radio wont enable.  They Show Admin Status Enable but Operational Status Down.
Any Ideas???
Similar issue discussed
Similar issue discussed here
https://supportforums.cisco.com/discussion/11236466/access-point-operational-status-shows-down-wlc
VIP Purple
May be this is a bug in 8.0
May be this is a bug in 8.0 specific to 2504. Better to reach TAC & see.
Make sure after the upgrade, all wlan are enable status & correctly map to defined dynamic interfaces.
If you have a console output of AP (when it power cycle) then pls attach that as it will tell the reason why radio go into disable mode.
Rasika
**** Pls rate all useful responses ****
This may be of power issue
118
