upgrade software on Cisco wireless lan controller 4402
I tried to upgrade a cisco lan controller 4402 whit a new version of Software.
the new version version is 4.0.155.0
I've read the user guide but the tftp go in error.
I can try to save the software on board, but not work.
I use PumpKin TFTP. Can you tell me a name of TFTP software that you use?
how can erase che old firmware?
In a router i use show flash or show bootflash but on this controller i don't find a command that look the name of the image.
What is the command for to erase the flash?
i use the command "transfer download"........
(Cisco Controller) >transfer download start
Mode............................................. TFTP
Data Type........................................ Code
TFTP Server IP................................... 192.168.138.201
TFTP Packet Timeout.............................. 20
TFTP Max Retries................................. 10
TFTP Path........................................ e:/
TFTP Filename.................................... AIR-WLC4400-K9-4-0-155-0.aes
This may take some time.
Are you sure you want to start? (y/N) y
TFTP Code transfer starting.
Code file transfer failed - Error from server: Access violation
----------- DEBUG ---------------------------
Cisco Controller) > DEBUG TRANSFER ALL ENABLE
Wed Jun 14 09:21:57 2006: RESULT_STRING: TFTP Code transfer starting.
Wed Jun 14 09:21:57 2006: RESULT_CODE:1
Wed Jun 14 09:22:00 2006: Still waiting! Status = 2
Wed Jun 14 09:22:01 2006: Locking tftp semaphore, pHost=192.168.138.201 pFilenam
e=e:/AIR-WLC4400-K9-4-0-155-0.aes
Wed Jun 14 09:22:02 2006: Semaphore locked, now unlocking, pHost=192.168.138.201
pFilename=e:/AIR-WLC4400-K9-4-0-155-0.aes
Wed Jun 14 09:22:02 2006: Semaphore successfully unlocked, pHost=192.168.138.201
Wed Jun 14 09:22:02 2006: TFTP: Binding to local=0.0.0.0 remote=192.168.138.201
Wed Jun 14 09:22:03 2006: Still waiting! Status = 1
Wed Jun 14 09:22:06 2006: Still waiting! Status = 1
Wed Jun 14 09:22:08 2006: tftp rc=1, pHost=192.168.138.201 pFilename=e:/AIR-WLC4
pLocalFilename=/mnt/download/local.tgz
Wed Jun 14 09:22:08 2006: tftp = 4, file_name=e:/AIR-WLC4400-K9-4-0-155-0.aes, i
p_address=192.168.138.201, msg=Error from server: Access violation
Wed Jun 14 09:22:08 2006: upd_get_code_via_tftp = 4 (target=296681472 msg=Error
from server: Access violation)
Wed Jun 14 09:22:08 2006: RESULT_STRING: Code file transfer failed - Error from
Wed Jun 14 09:22:08 2006: RESULT_CODE:12
Wed Jun 14 09:22:08 2006: ummounting: <umount /mnt/download/> cwd = /mnt/appli
cation
Wed Jun 14 09:22:08 2006: finished umounting
Re: upgrade software on Cisco wireless lan controller 4402
I can try also a .............
(Cisco Controller) >transfer upload start
Data Type........................................ Config File
Encryption....................................... Disabled
*** WARNING: Config File Encryption Disabled ***
TFTP Config transfer starting.
Config file transfer failed - Error from server: Access violation
(Cisco Controller) >debug transfer all enable
Wed Jun 14 09:24:15 2006: RESULT_STRING: TFTP Config transfer starting.
Wed Jun 14 09:24:15 2006: RESULT_CODE:1
Wed Jun 14 09:24:19 2006: Locking tftp semaphore, pHost=192.168.138.201 pFilenam
Wed Jun 14 09:24:20 2006: Semaphore locked, now unlocking, pHost=192.168.138.201
Wed Jun 14 09:24:20 2006: Semaphore successfully unlocked, pHost=192.168.138.201
Wed Jun 14 09:24:26 2006: tftp rc=1, pHost=192.168.138.201 pFilename=e:/AIR-WLC4
pLocalFilename=bigc
Wed Jun 14 09:24:26 2006: RESULT_STRING: Config file transfer failed - Error fro
Wed Jun 14 09:24:26 2006: RESULT_CODE:12
Bronze
I think the tftp path shoule not contain any drive symbols. Try to put the image file into the root directory of tftp server and specift "/" for "tftp path".
4170
