Community Member
Urgent: ACL on WLC 5508 + Transperant Proxy
I'm doing some experiment on a test SSID to configure ACL for limited resources on our Wired/Wireless network.
I'm/using and I would like to use Web Authentication page. I have created an ACL under Access Control List namely, ICT. With this, I have created an ACL rules as follows;
Seq     Action     Source IP/Mask     Destination IP/Mask     Protocol     Source Port     Dest Port     DSCP     Direction     Number of Hits
1    Permit    1.1.1.1 / 32    0.0.0.0 /0.0.0.0        TCP         Any         Any        Any    Outbound
2       Permit    0.0.0.0 / 32    1.1.1.1 /32             TCP        Any         Any        Any    Inbound
3    Permit    0.0.0.0 / 32    192.168.10.190 /32      UDP         DNS         Any        Any    Inbound
4    Permit    192.168.10.190/32 0.0.0.0 /0.0.0.0      UDP         DNS         Any        Any    Outbound
5    Permit    0.0.0.0 / 32    Proxy-vIP /32           Any         Any         Any        Any    Inbound
6    Permit    Proxy-vIP / 32    0.0.0.0 /0.0.0.0        Any         Any         Any        Any    Outbound
The authentication page comes fine, but as soon as I entered the username and password correctly, the page it doesn't redirect and IE error shows The Page cannot be displayed.
In the Edit Page of the WLAN ->Security -> Layer 3, I have selected the Preauthentication ACL as ICT, but still I can't browse the Internet..
Any help, highly appreciated.
Everyone's tags (5)
Community Member
I have changed the Rule of the Proxy to point to the proxy port itself, but still it doesn't work;
5    Permit    0.0.0.0 / 32    Proxy-vIP /32          TCP         8080         Any        Any    Inbound
6    Permit    Proxy-vIP / 32    0.0.0.0 /0.0.0.0        TCP        8080         Any        Any    Outbound
Community Member
Hello, yes it works without Proxy fine as we just configured PBR for WebSense..
is there any way to configure Auth-ACL ?
Silver
Does it work without ACL?
Did you enter the right proxy settings in your browser to be sure?
Posted by WebUser Erik Boss from Cisco Support Community App
Re: Urgent: ACL on WLC 5508 + Transperant Proxy
If you are looking to limit resources, why do it as a pre auth ACL? Just use a normal ACL linked to the interface to allow what the users can have access to.
Pre auth ACL are to allow the user to do something prior to them authenticating. Like reach an external web server
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Community Member
The purpose of this to have three separate SSIDs, each will have access to different resources. I have created one Ssid for testing and experimenting. I've just started creating ACLs and linked them to the Interface and to the SSID as well and I'm facing this issue as the client that connected to the same SSID cannot access the Internet.
Other ACLs such as DHCP and ICMP ping are working fine.. I have managed to create a rule to allow the client reaching the Authentication page, but when Username and password supplied, the page doesn't redirect to the external destination.
Any help?
I'm a few beers into the holiday week..
But, dhcp will always work because the wlc ACL doesn't and can't block broadcast and multicast traffic.
That traffic flows regardless. When you use proxy does the packets get written to the proxy server ? For giggles do a permit any any in line 7 ..
As Steve mentioned the preauth ACL is used for different purposes not what you are trying to do ..
Silver
and to block the data directly... Your option is also possible steprodr. But you're using the wireless network and then blocks it. Wasting your wireless bandwidth.
Community Member
Re:Urgent: ACL on WLC 5508 + Transperant Proxy
Could you plz elaborate? Where to block it then? At core switch level?
Sent from Cisco Technical Support Android App
Community Member
I think, this document is the one which I suppose to follow;
Web Authentication Proxy Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080c02f1e.shtml
Let me see how this can be done and I will update you guys.
Community Member
The Web Authentication proxy is for organizations who is having Explicit proxy in their browsers and want to implement Authentication Page from WLC. Sorry, this solution is not for what I'm intended to do.
I have created a test ACL as below and the internet started working, but this rule is nothing actually, becuase I started reaching everything on other vLANs.
Sequence
SourceAny
DestinationAny
ProtocolAny
DSCPAny
Direction Any
Action Permit
Community Member
I have installed WireSharek on the testing machine to test what's going on when an ACL is applied having limited ports to destination and with an ACL having;
Source = Any
Destination = Any
Protocol = Any
DSCP = Any
Direction = Any
Action = Permit
When this ACL is applied, the client immeditly reached the proxy and presented with the prompt authentication page.
In the wireshark, I can see Source port 54492 Dst port http-alt 8080 from the client IP address to the Proxy WebSense on the physical interface not the virtual interface.
Any thing can be done on this?
595
