Use 2504 WLC as Anchor Controller
Hello all,
This may be a thread already, but I am unable to find what I need.
I have the above mentioned controller which provides both DMZ access ( internet) and internal network access.Each type of network has a dedicated interface in the controller going to the switches.
I would like to encrypt the traffic from the laptops in the DMZ and use PSK, but I don't want a separate controller for that.
Can I use the existing one and is there any design I can find on it?
The OS version on the WLC is 7.5.102.
  Thanks&Regards,
  Vlad
1 REPLY
VIP Purple
Yes, you should be able to create two different SSID with different secuirty policy on the same controller (ex Guest SSID- WebAuth, Data SSID - WPA2/AES-PSK). You can map these two SSID for two different interfaces in DMZ switch  where you can control/isolate traffic between these two SSID.
Rasika
**** Pls rate all useful responses ****
162
