02-24-2012 12:52 PM - edited 07-03-2021 09:39 PM
All,
I have several autonomous 1240ag AP's that I need to enable a second ssid(Guest and VLAN2) for guest access and while I have configured the AP's according to the driections, I am not able to connect to the second ssid(Guest), but it is broadcasting. When I check the logs, I do not even see my laptop or any other device for that matter, trying to authenticate, what am I missing? I can see, connect and get an IP from the first ssid(Production and VLAN1), which is on the native VLAN and my 3COM 3C17203 switch port(14) is tagged for both VLAN's. Although I am sure that this would work better with a Catalyst switch, but it is not in my budget to replace all 4 of these, but I need this to work. Any ideas or suggestions to what I am missing.
Solved! Go to Solution.
02-24-2012 01:03 PM
Clarence,
you need to remove the mobility network-id 4
conf t
dot11 ssid Guest
no mobility network-id 4
end
wr
Then see if you can connect. The moblity network-id command is for use with the WLSM.
Steve
02-24-2012 01:03 PM
Clarence,
conf t
dot11 ssid Guest
end
wr
Steve
02-24-2012 01:45 PM
Steve,
I will give this a try on Monday and report my findings, as I am leaving for the weekend, but Thank You much for giving me another avenue to travel! If I know me, this is going to bother me all weekend and make me come back to the office to modify and see the results.
02-27-2012 05:50 AM
Steve,
Thank You much for the input, as it worked! Once I removed the mobility setting, I was able to connect to the second ssid and get the access that I expected.
