VLAN assignment from ACS not applied
WLC 4402 5.2.157.0
ACS Express 5.0.0.18
We have an issue where the VLAN assigned on the ACS isn't applied on the 4402 WLC.
We have 'Allow AAA Override' checked on the WLAN, the QoS is overridden to bronze properly, but the VLAN stays at 0 and the interface at management. The VLAN interface is configured on the WLC.
On the ACS the following are configured for the RADIUS response:
Radius-IETF Tunnel-Medium-Type 802
Radius-IETF Tunnel-Type VLAN
Radius-IETF Tunnel-Private-Group-ID 44
Cisco Airespace Airespace-QoS-Level Bronze
The accounting log shows:
Wed, 04 Feb 2009 09:50:02
User-Name = guest
NAS-IP-Address = 10.30.1.2
NAS-Port = 1
Framed-IP-Address = 10.30.1.12
Called-Station-Id = 10.30.1.2
Calling-Station-Id = 10.30.1.12
NAS-Identifier = Cisco4402WLC
Acct-Status-Type = Start
Acct-Session-Id = 4989b927/00:1a:73:ed:bf:ca/2
Acct-Authentic = RADIUS
Airespace-WLAN-Id = 2
Thanks for any help or advice you can provide to troubleshoot this issue.
-Brian
Re: VLAN assignment from ACS not applied
From the Clients -> Details screen on the WLC...
CLIENT PROPERTIES
MAC Address 00:1a:73:ed:bf:ca
IP Address 10.30.1.12
Client Type Regular
User Name guest
Port Number 1
Interface management
VLAN ID 0
CCX Version CCXv4
E2E Version Not Supported
Mobility Role Local
Mobility Peer IP Address N/A
Policy Manager State RUN
Mirror Mode Disable
Management Frame Protection No
SECURITY INFORMATION
Security Policy Completed Yes
Policy Type N/A
Encryption Cipher None
EAP Type N/A
NAC State Access
QUALITY OF SERVICE PROPERTIES
WMM State Enabled
U-APSD Support Disabled
QoS Level Bronze
Diff Serv Code Point (DSCP) disabled
802.1p Tag disabled
Average Data Rate disabled
Average Real-Time Rate disabled
Burst Data Rate disabled
Burst Real-Time Rate disabled
when you are trying to use AAA to change the vlan the client is using on a WLC, you don't use the VLAN number, you use the interface name. So for :
use the interface name and not the VLAN number.
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Steve, Thank you for your response, however changing it to the interface name did not change the result. The VLAN is still untagged and using the management interface.
Do you have any other suggestions I can try?
Brian
I also noticed the Radius-IETF Session-Timeout isn't being applied.
Based on http://www.cisco.com/en/US/products/ps6307/products_tech_note09186a0080870334.shtml it appears that isn't a supported attribute though.
364
