01-29-2012 09:08 PM - edited 07-03-2021 09:28 PM
Folks,
I have a requriement where the ACS server should send the vlan information based on SSID the user connected with.
Can I do this in ACS 5.0. I know I have to write a policy. But can not find a fild for SSID.
Any advice would be highly appreciated.
Parwal
01-29-2012 11:07 PM
You can do that on ACS. For the SSID filtering you have to create an end station filter using the DNIS: *SSID
You have to then place that in your policy. You can also specify the vlan assignment.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.2/user/guide/policy_mod.html
01-30-2012 04:58 AM
If you want to do dynamic vlan assignment, you configure the vlan assignment in ACS under Policy Elements |
Authorization and Permissions | Network Access | Authorization Profiles
To specify the SSID:
Authorization and Permissions | Network Conditions | End Station Filters
