Community Member
W2K MS-Peap in combination with AP1200 IOS 12.2(11)JA and MS IAS
With several wireless adapters (Proxim A/B Combo, 3Com 3CRWE62092B, etc) we are experiencing problems using MS-Peap on W2K in combination with the AP1200 running IOS 12.2(11)JA and MS IAS (Both 2000 and .Net)
Very often svchost.exe crashes and the 'Wireless configuration' service
stops. Which results in a lost connection.
Has anyone the same problem, or even better; How can I solve it?
Regards Alexander
1 REPLY
Bronze
Re: W2K MS-Peap in combination with AP1200 IOS 12.2(11)JA and MS
Check the following points,
The IAS must have a valid cert from the cert server installed,
The Cisco PEAP was *never* installed on the client (as once
installed there is no way to revert back to the MS PEAP supplicant).
Is the client machine a member of the domain (if so, then it will need a
cert from the cert server installed on it before the authenication will work correctly)
175
