WAP is not authenticated to WLSE?
I'm trying to set up WDS with 2 Cisco 1130 WAP, 1 ACS (V3.3) and Cisco WLSE.
I got everything working except for connecting WDS access point to WLSE.
I put WLSE's ip address in WNM global configuration but I see this access point constantly generating error messages saying 'Not authenticated'.
WLSE had this devide under 'Managed Devices' but does it need additional configuration to talk to WDS access point?
Thanks for your help in advance.
  • Security and Network Management
1 REPLY
Bronze
Re: WAP is not authenticated to WLSE?
I believe you are seeing this bug:
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsb47726&Submit=Search
There is not a very good workaround. You can downgrade ACS to 3.3.2 or run local authentication on the AP for WDS.
What you will see if you debug radius on the WDS primary are access-request and access-challenge but never an access-accept.
118
