WAP personal Authentication of Cisco Aironet 1140 does not work for MACbooks.
I have a Cisco Aironet 1140 with ENABLED broadcasting SSID, encryption is WPA2(personal).
Ubuntu 12.04 and Windows 7 are authenticated, but MACBooks never be authenticated.
Anyone know special configuration for MAC books?
With my best regards,
c1141-142#show version
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JY, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Apr-10 10:20 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA1, RELEASE SOFTWARE (fc1)
c1141-142 uptime is 3 days, 22 hours, 43 minutes
System returned to ROM by reload
System image file is "flash:/c1140-k9w7-mx.124-21a.JY/c1140-k9w7-mx.124-21a.JY"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1142N-P-K9     (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FGL1532S7JJ
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from reload
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 70:81:05:06:E1:3F
Part Number                          : 73-12836-03
PCA Assembly Number                  : 800-33767-03
PCA Revision Number                  : A0
PCB Serial Number                    : FOC15282H8M
Top Assembly Part Number             : 800-33775-02
Top Assembly Serial Number           : FGL1532S7JJ
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1142N-P-K9
Configuration register is 0xF
c1141-142#
c1141-142#show run
Building configuration...
Current configuration : 2192 bytes
version 12.4
no service pad
service password-encryption
hostname c1141-142
logging buffered 8192 debugging
enable secret 5 $1$wN77$SjdD8e/zS2Ok9XGcB53TZ/
no aaa new-model
no ip domain lookup
dot11 syslog
dot11 ssid AirPort-Test-Cisco
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii ********************************
username Cisco privilege 15 password 7 13061E01080344
username view password 7 1058001C12
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
antenna gain 0
speed  basic-5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
power local 2
channel 2462
station-role root
no dot11 extension aironet
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
antenna gain 0
no dfs band block
speed  basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
power local 2
channel 5300
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.20.142 255.255.254.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
logging synchronous
line vty 0 4
password 7 047802150C2E
logging synchronous
login
end
1 ACCEPTED SOLUTION
Bronze
Here is a config exmaople with an AP that has an IP address for vlan 1 and working with 2 ssids one for vlan 1 and one for vlan 3 both using WPA version 2 with AES + PSK and  the PSK is cisco12345
version 12.4
no service pad
hostname AP1142AG.246
enable secret 5 $1$ONOn$EFmsjtV4qtvRCbfAqDbIG1
no aaa new-model
dot11 syslog
dot11 ssid test vlan 1
   vlan 1
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 14141B180F0B7B7977
dot11 ssid test vlan 30
   vlan 30
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 01100F175804575D72181B
username Cisco password 7 1531021F0725
bridge irb
 no ip address
 no ip route-cache
 encryption vlan 1 mode ciphers aes-ccm
 encryption vlan 30 mode ciphers aes-ccm
 ssid test vlan 1
 ssid test vlan 30
 antenna gain 0
 mbssid
 speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 channel 2412
 station-role root
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
interface Dot11Radio0.30
 encapsulation dot1Q 30
 no ip route-cache
 bridge-group 30
 bridge-group 30 subscriber-loop-control
 bridge-group 30 block-unknown-source
 no bridge-group 30 source-learning
 no bridge-group 30 unicast-flooding
 bridge-group 30 spanning-disabled
 no ip address
 no ip route-cache
 ssid test vlan 1
 ssid test vlan 30
 antenna gain 0
 dfs band 3 block
 mbssid
 speed  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 channel dfs
 station-role root
interface Dot11Radio1.1
 no ip route-cache
 bridge-group 1
interface Dot11Radio1.30
 no ip route-cache
 bridge-group 30
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
interface GigabitEthernet0.1
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0.30
 no ip route-cache
 bridge-group 30
interface BVI1
 ip address dhcp client-id GigabitEthernet0
 no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
Bronze
As you mention you have the AP configured to work with WPA 2, I checked the configuration you attached and you have configured WPA version 2 under the SSID but under the encryption method on the radio you are using TKIP.
As per the WiFi alliance when we are working with WPA version 1 we use the cipher known as TKIP and when working with WPA version 2 we use the cipher known as AES-CCM, so please change the encryption from TKIP to AES-CCM.
Let me know how it goes.
fbarboza:
I tried WPA version 2 with AES-CCM and WPA version 1 with TKIP.
MacBook Air does not work fine. following configuration is OK?
   authentication open
   authentication key-management wpa version 1
   guest-mode
   wpa-psk ascii 7 045702100A3249401A1C4845425B5A54787B7C
   authentication open
   guest-mode
encryption mode ciphers aes-ccm tkip
I tried to investigate debug messages.
When I connect Ubuntu machines, Cisco debug messages say
c1141-143#debug dot11 mgmt msg
IEEE 802.11 packets debugging is on
c1141-143#debug dot11 mgmt state-machine
dot11 state machine debugging is on
c1141-143#
c1141-143#
c1141-143#
*Mar  2 11:07:18.637: SM: ---Open Authentication 0x13B1F50: AuthReq (0)
*Mar  2 11:07:18.637: SM:    Init (0) --> Auth_not_Assoc (1)
*Mar  2 11:07:18.637: dot11_mgmt: [AEB4117] send auth=0, status[0] to dst=2477.035f.2630, src=a0cf.5b69.3280, bssid=a0cf.5b69.3280, seq=2, if=Dot11Radio0
*Mar  2 11:07:18.637:  Incoming bssid a0cf.5b69.3280 is valid , client 2477.035f.2630
*Mar  2 11:07:18.641: SM: ---Open Authentication 0x13B1F50: AssocReq (1)
*Mar  2 11:07:18.641: SM:    Auth_not_Assoc (1) --> DONT CHANGE STATE (255)
*Mar  2 11:07:18.641: SM: ---Open Authentication 0x13B1F50: IAPP-Resp (3)
*Mar  2 11:07:18.641: SM:    IAPP_get (5) --> DONT CHANGE STATE (255)
*Mar  2 11:07:18.641: dot11_mgmt: dot11_mgmt_smact_iapp_resp: bss clnt
*Mar  2 11:07:18.641: dot11_mgmt: [AEB5190] request driver to add client 2477.035f.2630
*Mar  2 11:07:18.642: SM: ---Open Authentication 0x13B1F50: Drv Add Resp (8)
*Mar  2 11:07:18.642: SM:    Drv_Add_InProg (8) --> DONT CHANGE STATE (255)
*Mar  2 11:07:18.642: dot11_mgmt: [AEB5321] response from driver for client 2477.035f.2630
*Mar  2 11:07:18.642: dot11_mgmt: [AEB5357] send reassoc resp, status[0] to dst=2477.035f.2630, aid[1] on Dot11Radio0
*Mar  2 11:07:18.661: SM: ---Open Authentication 0x13B1F50: AAA Auth OK (5)
*Mar  2 11:07:18.661: SM:    AAA_Auth (6) --> Assoc (2)
*Mar  2 11:07:18.661: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   2477.035f.2630 Reassociated KEY_MGMT[WPAv2 PSK]
c1141-143#
When I connect MacBooks, Cisco debug messages say
c1141-143#
*Mar  2 11:39:11.524: SM: ---Open Authentication 0x13B1A60: AuthReq (0)
*Mar  2 11:39:11.525: SM:    Init (0) --> Auth_not_Assoc (1)
*Mar  2 11:39:11.525: dot11_mgmt: [7CEF991E] send auth=0, status[0] to dst=b88d.1217.72bc, src=a0cf.5b74.8710, bssid=a0cf.5b74.8710, seq=2, if=Dot11Radio1
*Mar  2 11:39:11.525:  Incoming bssid a0cf.5b74.8710 is valid , client b88d.1217.72bc
*Mar  2 11:39:11.525: SM: ---Open Authentication 0x13B1A60: AssocReq (1)
*Mar  2 11:39:11.525: SM:    Auth_not_Assoc (1) --> DONT CHANGE STATE (255)
*Mar  2 11:39:11.525: SM: ---Open Authentication 0x13B1A60: IAPP-Resp (3)
*Mar  2 11:39:11.525: SM:    IAPP_get (5) --> DONT CHANGE STATE (255)
*Mar  2 11:39:11.525: dot11_mgmt: dot11_mgmt_smact_iapp_resp: bss clnt
*Mar  2 11:39:11.525: dot11_mgmt: [7CEF9CE7] request driver to add client b88d.1217.72bc
*Mar  2 11:39:11.526: SM: ---Open Authentication 0x13B1A60: Drv Add Resp (8)
*Mar  2 11:39:11.526: SM:    Drv_Add_InProg (8) --> DONT CHANGE STATE (255)
*Mar  2 11:39:11.526: dot11_mgmt: [7CEF9EDC] response from driver for client b88d.1217.72bc
*Mar  2 11:39:11.526: dot11_mgmt: [7CEF9F18] send assoc resp, status[0] to dst=b88d.1217.72bc, aid[1] on Dot11Radio1
*Mar  2 11:39:11.829: SM: ---Open Authentication 0x13B1A60: AAA Auth OK (5)
*Mar  2 11:39:11.829: SM:    AAA_Auth (6) --> Assoc (2)
c1141-143#
*Mar  2 11:39:11.829: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   b88d.1217.72bc Associated KEY_MGMT[WPAv2 PSK]
c1141-143#
*Mar  2 11:39:19.819:  dot11_mgmt: de-auth msg sent with reason = 2
*Mar  2 11:39:19.819: SM: ---Open Authentication 0x13B1A60: Delete (2)
*Mar  2 11:39:19.819: SM:    Assoc (2) --> Init (0)
c1141-143#
*Mar  2 11:39:19.819: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station b88d.1217.72bc Reason: Sending station has left the BSS
c1141-143#
I think your comment makes sense and there is probles except AES-CCM.
Bronze
On the confi you attach it shows that for one you use only WPA version 1 with TKIP as the encryption but you still shows the command "encryption mode ciphers aes-ccm tkip" and should be "encryption mode ciphers aes-ccm" or
"encryption mode ciphers tkip" if you enable WPA version 2 under the SSID or WPA version 1 under the SSID.
Also if you want to broadcast 2 SSIDs you need to enable first mbssd under the radio itself and then under the SSID we use mbssid guest mode instead of guest mode.
Try to reset the AP to defaults and reconfigure it.
I will upload a confi example.
Bronze
version 12.4
no service pad
no aaa new-model
dot11 syslog
   vlan 1
   authentication open
   mbssid guest-mode
   vlan 30
   authentication open
   mbssid guest-mode
bridge irb
 no ip address
 no ip route-cache
 ssid test vlan 1
 ssid test vlan 30
 antenna gain 0
 mbssid
 channel 2412
 station-role root
 no ip route-cache
 bridge-group 1
 no ip route-cache
 bridge-group 30
 no ip address
 no ip route-cache
 ssid test vlan 1
 ssid test vlan 30
 antenna gain 0
 dfs band 3 block
 mbssid
 channel dfs
 station-role root
 no ip route-cache
 bridge-group 1
 no ip route-cache
 bridge-group 30
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
 no ip route-cache
 bridge-group 1
 no ip route-cache
 bridge-group 30
interface BVI1
 no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
fbarboza:
Your configuration does work! Thank you!
Bronze
Glad to know it is working.
6545
