WAP200 - How many simultaneous connections are supported?
Thanks.
Bryan Hunt
A little late in the reply, but not many, I would say 15 before you start to run into issues
VIP Purple
HI Brayan,
I was using this earlier and i will suggest not to use more then 20 connection simultaneously.
What you need to remember is that the bandwidth your have xx is the total bandwidth available. As this is shared amoungst users the available bandwidth to the users becomes smaller. xx/users=available bandwidth in rough terms.
Dont forget to rate helpful posts
572
